boost question
boost question
My 1993 B-5.9-160, Cummins manual I have calls for 10psi at idle and 30psi at rated rpm. Does 10psi more at rated rpm (40psi) really make that much difference? How or does that change your rpm shift range in a stick. I have a Getrag 5 speed with 3-56 gears in the dana 70 rear, the motor winds out at 15mph in 2nd, 32mph in 3rd, 52mph in 4th and 75mph in 5th seems to be screaming. I have no tack, the truck was not equiped from the factory. I assume cummins only installed a tack drive somewhere when orded from chry.
Dave.
Dave.
Dah. Thats correct, I better reread my stuff. What about the other discriptions with factory tack hookup and shift ranges? Also my turbo doesn't have a waste gate, is this the baby turbo offered at time of orded in `93`
The "Baby" H1C is standard on the 89-91 NON-IC. There were no turbo "options."
The only difference in turbos from 91-93 is the exhaust housings and I think their differences were determined by the transmission option.
Dave
You might want to fill out your sig so we can see what you've got. From what I read it looks as if you are running a Getrag tranny. Over filling it by a quart should help to quiet it down - at least you will know if it's the engine or trans that is making the noise - I would bet on the tranny. From the mph in each gear and top speed of 75 mph it sounds bas if you are running 411s in the rear diff. There is a lot of good info in the stickies and all 1st gen posters are more than willing to help.
Bob
Bob
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
