1993 Dodge Ram 2500 truck not start, Speedometer/odometer issues
Old Jun 22, 2016 | 12:54 AM
FreeBird5.9's Avatar
My speedo is not working on my 1993 Dodge Ram W250 Manual trans and recently started reading up to 100miles/hr while only going about 10 and the odometer would also click away even when stopped. To avoid all the extra miles I tried to unplug the sensor and start the truck while waiting for the new speedo to come tomorrow. It cranked but did not start. I realized that was completely idiotic the second after and plugged it back in, but it cranked without starting up again. Solutions to any problem would be greatly appreciated
Old Jun 22, 2016 | 08:22 AM
Unplugging the VSS at the T-case should not effect starting and driving the truck.
Could you have bumped the FSS [fuel shut off solenoid] at the injection pump?
Is it getting fuel to the injectors?
Old Jun 22, 2016 | 01:50 PM
I definitely did not bump the fuel shut off solenoid. It seems there is no fuel getting to the injectors. The truck started half crank for the past two weeks until I screwed with the speed sensor!
Old Jun 22, 2016 | 01:57 PM
Also, the Wait to start and water in fuel light do not turn on at all.
Old Jun 22, 2016 | 08:55 PM
Ordered some glow plugs as there is still fuel pumping from the injectors. Could be the glow plug relay
Old Jun 22, 2016 | 09:08 PM
Who sold you glow plugs for a Cummins???
They might not be your friend.
If here is fuel to the injectors and it turns over well, it should start.
Old Jun 22, 2016 | 10:26 PM
Mike L's Avatar
Wait, Whaaaaaaat?????
Old Jun 23, 2016 | 08:47 AM
Let me try to help some more.
Cummins motors DO NOT take glow plugs, return those and never use that company that was trying to sell them to you again.
Cummins motor use a grid heater, which since it is summer will not be needed.
I know people that have started Cummins motors well below 0F* without them, so that is not your no start issue.
Make sure all the injectors are getting fuel, by either using the primer lever on the lift pump or by bumping the motor over a bit with the starter while the lines are cracked open.
If they are getting fuel, close them down, turn the key and you should be up and running.
I repeat, NO glow plugs
Old Jun 23, 2016 | 09:13 AM
Angry Johnny's Avatar
I bet that place has a water pump for my '68 VW bug too.
Old Jun 23, 2016 | 11:23 AM
Sorry I meant the grid heater. I checked all of the injectors and they where all pumping when the truck was cranking. The reason I thought it was the heater was that the battery reading is at zero when I turn the key where it usually bumped up to 12 volts when cranking. Thanks Oliver, I didn't know that a 12 v could start without a heater
Old Jun 23, 2016 | 12:13 PM
Time for a new battery then maybe?
Old Jun 23, 2016 | 12:21 PM
She is cranking really hard, but the terminals are a bit rusted. Might try a new battery, grid heater, and possibly a new harness. Anything else I should look at replacing?
Old Jun 23, 2016 | 12:38 PM
You need a strong battery [so it cranks over well], fuel at the injectors [which means the FSS is working] and it should run.
No need for swapping grid heaters and new wiring.
I can get one running on my shop floor with one wire to the FSS, a battery and a jug of fuel.
Old May 2, 2019 | 09:37 PM
j_martin's Avatar
That's another problem, preceeding the overdrive issue. Either the PCM is knackered, or it's not getting the start up sequenced power. Looking at the diagrams, there's one power all the time wire to the PCM. Then there's a keyed power wire to it. When that goes high, the PCM then powers the ASD relay, which then sends "ASD POWER" to the PCM. Only then will the PCM run and drive the dash lights, grid heater relays, OD, tachometer, generator, etc
Exekiel69
May 20, 2012 08:05 PM
Montana2x2
Jul 5, 2011 07:50 PM
spitzair
Aug 28, 2006 01:25 PM
Mosh
14
May 28, 2006 06:41 AM
mytrucksaslug
May 26, 2006 10:00 AM
