loydrell wants to know about fuel pin butchery
Old 12-22-2006, 09:38 AM
loydrell's Avatar
Question loydrell wants to know about fuel pin butchery
could somewone please explane the butchered fuel pin for me? thank you. 93 extened cab auto stock
Old 12-22-2006, 10:29 AM
2stroke's Avatar
https://www.dieseltruckresource.com/...d.php?t=128522
does this help?
Old 12-22-2006, 04:12 PM
Are you talking about the one in my sig? A previous owner did a hack job on mine, it's a very non-traditional grind. The profile is stock, but the ramp was extended up past where the fuel pin would normally ride, and the nylon spacer washer that limits travel was removed.
Old 12-24-2006, 04:00 PM
loydrell's Avatar
fuel pin
Do you have a picture of your butchered pin posted
No, but that can be arranged.
Old 12-24-2006, 04:35 PM
Wink Pics from 3 angles - ask and ye shall receive
Old 12-25-2006, 09:25 AM
loydrell's Avatar
fuel pin
thank you for the great pictures of the fuel pin. I have an extra pin, so I think I will give it a try.
Old 12-26-2006, 04:44 AM
KRB
KRB's Avatar
How does it perform (being a nontraditional butchery)?
KRB
Old 12-26-2006, 04:03 PM
I think it's a good setup for a truck with big injectors. When you have POD's or similar your focus changes from trying to get a lot of fuel to get the turbo spooled to trying to delay the fuel until the turbo spools.
Lorydrell, for your stock truck a more traditional grind (more fuel sooner) would be a better setup.
Old 12-26-2006, 06:05 PM
G1625S's Avatar
Hey Dave, do you think the cone bottoms out before the pin can ride the entire profile...even without the washer?
Old 12-26-2006, 06:48 PM
Yes. You can't see the wear mark real well in the pic, but it only goes to about even with the "step" where the stock profile starts.
Old 01-08-2007, 04:27 PM
loydrell's Avatar
Hi Dave, I just gave my pin a very light grind. With full fuel, star wheel down, and full in on fuel adj,I get 30 lbs boost and it feels a lot more powerful. Ilike it a lot better. It seems to run with a 99 powerstroke. Thanks for all the help
Old 01-08-2007, 05:23 PM
2stroke's Avatar
loydrell.. did u take a picture of ur pin?
Old 01-11-2007, 09:52 AM
loydrell's Avatar
pin
no pics I turned the pin 90 degrees from the deep side and ground it to the same depth plus about .020 as the same as if it was turned to the full fuel side plus more clearance at the top for full pin travel. My taper only goes about 3/8" down from the top. It might not be enough, but can be turned back if not satisfied.
Old 01-11-2007, 04:18 PM
dpuckett's Avatar
I did the same thing in mine, as I am happy with my bottom end fuel, just wanted more as it came on. I took mine to about the 75% lean side, and started my grind about halfway up, angling in a hair more, to get to about what full fuel would be on the deep side, plus a goodly amount. Took a little less than half the neck away. Any more than that, and I fear it would break off inside the housing, virtually eliminating the AFC function.
My pump will now run with a 99PSD if I unhook the AFC hose.
Diesel Dynamics (now Edge, i believe) had a fuel pin several years ago,and it had a 2 stage taper. Only problem was, though it did cut bottom end smoke, it also cut top end fuelling, as it wasnt offset like the stock pin. I based my grind off a combination of their profile and Old Smoky's pin profile. It is truly a custom job, one of a kind. I just need softer spring. I also ditched the nylon washer. Figure if it was good enough for DD, it was good enough for me.
Daniel
gaberichison
12-21-2014 12:21 PM
Cowboy_Customs
10-18-2011 01:46 AM
bigragu
10-17-2005 04:07 PM
timdewaltman
15
12-20-2002 06:50 AM
Quick Reply: loydrell wants to know about fuel pin butchery
