Towing with a new diesel
That was May of last year. By Xmas, I had just shy of 99,000 miles of hotshot hauling on the truck with absolutely no problems at all.
Damlier-Chrysler recommends that you vary your speeds for the first 500 miles or so, they suggest you not just put it on cruise and stay at a steady pace. They suggest you do no more than 40 or 50 miles at one speed, then go faster for 40 or 50, then slower, etc.
After the first 500 miles or so, then you can haul all day at any speed you want.
Plus, you will need to be religous about changing oil for the first 10 or so oil changes (I have always used Rotella).
My mileage started off at about 9.4 average under tow, and when I sold my business in May was getting about 12.9 with the same loads. So you can look for an improvement in fuel mileage with time, also.
Hope this helps.
I read on another forum (I think BD Power?) that the Cummins is ready to tow right away. If it was me, just like coolvanilla, I would have no concerns about towing ASAP. It seems like the guys who tow the hardest, have the most efficient motors.
I concur.
You want to get a good load behind it, but I thought you SHOULD vary your speed, and NOT use Cruise Control. That is contrary to CoolVanilla's advice, I konw. He is probably right because he towed for a living.
I had to edit my message, you must have read my response before I reworded it.
One MUST vary the speed for the first 500 miles (according to D-C). I did, and have had no problems.
G
G
When I was still driving OTR, the way we broke in new tractors is hook up to the heaviest and longest load possible and get her hot (watching the pyro of course) for as long as you could sit in the seat - no messin' around.
The engine is good to tow right out of the box.You're supposed to run reduced loads for about 500 miles to seat the ring gear in the diff.Then tow it like you stole it.
Where would you say that ring gear would get a better break in? I have to sit back and wonder where these engineers come up with this stuff.
The key to ring gear break-in is to temper the gears with lots of heating and cooling cycles. The best way to do that is pull a moderate load on the surface streets (no highway) for a while.
Of course, I just hooked up and hammered it! I think its cool when you roast the tires while accelerating with a 10,000 lb trailer behind you!
DirtEater
03-31-2006 02:28 PM
OOPS
08-28-2004 07:15 PM
