EGT when towing?
Old Nov 17, 2006 | 12:05 PM
REF>Lancer's Avatar
I had my backdown set at 1350 and melted er down after about 3 miles of hard pull....I have since started backing down at 1200...and it don't get near as hot now that I have had the valves adjusted...they had to do that when they re-installed the head when #6 was replaced....carefull with the EGT's Gents
Old Nov 17, 2006 | 12:42 PM
jrussell's Avatar
Originally Posted by one4speed
'03-07 can run much hotter than your '93. 1400 isn't unusual. You will melt a piston way before you do any turbo damage. Watch the water temp gauge that one is REALLY important!
one4
Yeah, I figured there would be a little more heat stock since it has double the power.
It just amazes me that DC/Cummins will let a stock motor go that high. I was always under the impression you can push a stock diesel as hard as you want without having to worry about EGT's. If it will get to 1300-1400* stock then why don't they come with a Pyro?!?!
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
GO 4LO
May 10, 2004 08:41 AM
barracuda
Apr 16, 2003 07:36 PM
