Twins-low EGT's, single-high EGT's
Old Nov 16, 2006 | 04:06 PM
jmccart's Avatar
Why do twins make lower EGT's than singles?
Thanx.
Old Nov 16, 2006 | 04:08 PM
JD Dearden's Avatar
Because you are pushing more air and burning more fuel. Also some guys will make let say 55 psi of boost with twins and I can make 45 to 50 with my 66, but this is can be tricky because he is shoving a barrel of air through while I am shoving a milk jug.
Old Nov 17, 2006 | 09:41 PM
jmccart's Avatar
So even if the boost was the same, for a single vs a twin, there is more actual air in the cylinder with the twins? And more ari means cooler EGT's?
Is that right?
Thanx.
Old Nov 17, 2006 | 09:43 PM
morkable's Avatar
you got'er Pontiac. It is a neat and complicated thing, but that is the basics of it
Kevin
Old Nov 17, 2006 | 09:45 PM
jmccart's Avatar
Thanx guys, I needed that.
Old Nov 17, 2006 | 10:14 PM
PourinDiesel's Avatar
Thats actually not why but you have the right idea going.
Twin turbo's often produce lower egt's do to the fact that you are working within the two turbo's efficiency ranges. Single Turbo's typically are working harder with higher shaft speeds to produce the same amount of boost. -----Which will result in higher charge air temperatures resulting in a less efficient combustion event.
Old Nov 17, 2006 | 10:33 PM
madhat's Avatar
Administrator/Jarhead
You've got two guys doing the work of one... Less broke off = less sweat...
Old Nov 18, 2006 | 12:05 AM
jmccart's Avatar
It kind of seems like 50lbs of boost is 50lbs of boost, no matter how you get it. But is it the single turbo is making twice as much heat, with one spinning shaft at a certain boost than twins would with two shafts making that same amount of total boost? Does the one shaft between impellers (right term?) get so hot, it heats up the the metal on the intake impeller, which heats up the air?
Thanx.
Old Nov 18, 2006 | 12:33 AM
No, its compressing air at a higher rate of speed which increases air temp to an extreme.
Old Nov 18, 2006 | 03:06 AM
qmcdt's Avatar
Heat of Compression
A centrifical compressor that is operating inside it's ideal operating range, does so without adding more energy to the air then what the air already has in it. (in theory of course, friction is always at play.) The further outside this range the unit is run, the more friction there is between the impeller and the air. Simply put, 50 psi boost at 125 degrees f from twins versus 50 psi boost at 200 degrees f from a single running at the edge of it's operating range, the first has a larger mass due to lower temperature. Thus when it comes to the EGT end of it think of it as trying to heat 5lbs of air with 2cc's of fuel verses heating 2lbs of air with 2cc's of fuel. (assuming you've made no changes in Fuel flow) The temperature won't climb as high, but you will get a larger pressure increase in the cylinder's. Another option is to install a bigger/more efficient intercooler to drop the temperature from your fatshaft 62 or what have you, but you would also see a subsiquent drop in the boost pressure because you will then be thermally compressing the discharge flow of the turbo, thus lowering the backpressure in it, but it would help to increase the mass flow and lower the egt's. My question awhile ago was why they don't intercool between and after the twins, but I guess fitting a 2nd intercooler would be no small task.
Old Nov 18, 2006 | 01:37 PM
jmccart's Avatar
That's good.
Thanx.
Old Nov 18, 2006 | 06:42 PM
qmcdt's Avatar
r u sure?
I've got more. hehehe
Old Nov 19, 2006 | 12:12 AM
AK RAM's Avatar
Can we get an interpreter here?….someone that speaks English? That's one of the better explanations I've heard in a long time. You rock.
Old Nov 20, 2006 | 06:19 PM
blackmoke's Avatar
Man, wish I could get high egt's with my Silver Bullet
Old Nov 20, 2006 | 06:45 PM
masonic-dodge's Avatar
Throw a 12000lbs 5th wheel on your truck in stop and go traffic That will bring your EGTs up.
CRIS
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
06dmc
19
Aug 9, 2006 12:54 AM
