Distribution hitch vs Sway control hitch
Old Oct 23, 2007 | 05:28 PM
ptgarcia's Avatar
Everyone needs to remember that the factory hitch is only rated for 500 lbs of tongue weight without a weight distribution hitch. And our hitches aren't the best, so I'd closely follow this rating.
Old Oct 23, 2007 | 10:33 PM
Quiky One's Avatar
Can you back up without unhooking the equalizer hitch?
Old Oct 24, 2007 | 12:31 AM
falstaff's Avatar
Yes thats one of the reasons I bought it. The kinds with the chains (no chains on Eqaulizer) you have to unhook the chains- a real PITA...
You don't have to drill/weld holes in the frame like the Reese dual cam requires either. Super easy to install and calibrate for your vehicle too
Old Oct 24, 2007 | 12:36 AM
ptgarcia's Avatar
Originally Posted by falstaff
The kinds with the chains you have to unhook the chains- a real PITA...
Again, not true. I never unhook my dual cam while backing.
Old Oct 24, 2007 | 08:50 AM
hubmonkey's Avatar
I have spring bars and do not take them off when backing up. I only remove the friction sway bar off because it will bind.
Hub
Old Oct 25, 2007 | 02:11 AM
TrueBlueInBak's Avatar
WD backing up
You can back up without any troubles as long as you don't go overboard on your turning radius. I made that mistake on my first trailer and got lucky and only busted a mounting bolt. The easiest way around that is to release the bars. I've never pulled the trundle style, so I have no insights into those.
Old Oct 25, 2007 | 10:33 AM
Springer's Avatar
12 years with the Reese dual cam sway control and I have never had to unhook the bars while backing and I have been so tight that the trailer is almost 90 degrees to the truck. This happens when I put the trailer in its parking spot at home.
The only thing about them that I don’t like is they make a lot of noise when turning even if you lube them. I was told by a Reese tech the recommended lube is Vaseline on the sway control. And a very small amount at that
Old Oct 25, 2007 | 11:59 AM
REF>Lancer's Avatar
He said it was passing semi's,thats a problem I've yet to find a solution for.
Theres a art to it,when you get about even with the trailer of the semi it pulls you towards it,then next to the tractor it starts to you away,then when the front of your trailer is even with the front of the tractor it steers you towards the truck again,then when the rear of your trailer is going past the truck it gives you an extra wiggle...(usually away,making you look goofy!)
TIM RYDEN
May 9, 2005 04:42 PM
rws
Mar 11, 2005 11:43 AM
Dodgezilla
Nov 14, 2004 09:59 PM
drno
Jun 7, 2004 10:32 AM
thatguy
Oct 29, 2002 07:21 PM
