wrong year ez???
Old Sep 7, 2007 | 10:05 AM
bullboy85's Avatar
wrong year ez???
ok i bought my truck a fuw months ago and have seemed to have little things go wrong with it sence i got it. heres the newest, i just found out that the ez module that came with my truck is for a 2001 not 1999. other then different conecters is that really a big deal???
Old Sep 7, 2007 | 10:30 AM
AggieJustin's Avatar
Yeah, that module won't work on the '99 because the voltage values for the MAP sensor are different. Between '01 and '02 they make adapter plugs so they can interchange, but '98.5-'00 are their own box.
Old Sep 7, 2007 | 11:40 AM
bullboy85's Avatar
ok so this box probibly explans low milage, my motor has 124000 miles and already has blow by could this chip of caused that?
Old Sep 7, 2007 | 11:44 AM
So you're saying you have this box plugged in? How did the connectors managed to get hooked up? As far as I know, the connectors were completely different between the '99 and the '01.
I doubt it would cause blow by, but it might explain low mileage. I'd have to look at the voltage specs, but the boost fooling function could be sending incorrect boost readings to the computer which could screw with mileage.
Old Sep 7, 2007 | 11:51 AM
bullboy85's Avatar
i dont know, it was already on there when i got it so i never thought to check and make sure it was the right yr
Old Sep 7, 2007 | 12:01 PM
pmtg's Avatar
look on the back of the EZ and get the model number off of it....
if its EZD1000, it is correct for your year truck.
if its EZD1000A or EZD1000B, it is not the correct year for your truck.
Old Mar 18, 2010 | 02:28 PM
wschwurack's Avatar
I have EZD1000A, will this fit on a 2002? or only on a 2001
Wolf
Old Mar 18, 2010 | 10:58 PM
nickg's Avatar
Wolf,
welcome to the forum.
This is a very old thread, kudo's to you for using the search function.
I just googled your part number and its for a 2001
When I bought mine it came with the adapter to use it on an 02, so it will fit both yrs, but needs the MAP adapter to work on the 02
http://www.shopdieselspecialists.com...ct-p/30201.htm
trophystock
Jul 16, 2006 11:00 AM
HammerLane
Nov 24, 2004 03:09 PM
redruM Hauler
Sep 28, 2004 09:42 PM
