transmission problem
Old Mar 4, 2009 | 05:35 PM
powermad's Avatar
so i just had all the stuff in my sig installed into a brand new 47re. for the first time i tried to do a 4x4 launch. when i was building boost my boost gauge went from 15 down to 8 and then back up to 15 then down to 10 and when i launched it felt like first gear was slipping then when i let off and took it out of 4 wheel drive and slowed down to around 30mph it down shifts into second!?! is there a adjustment i might need to mess with? kickdown cable?
Old Mar 4, 2009 | 07:21 PM
scottsjeeprolet's Avatar
Call DAVE! He stands behind his stuff and will know how to fix.
Old Mar 4, 2009 | 08:13 PM
ctd89-99's Avatar
X ' S 2. Thanks Steve B.
Old Mar 4, 2009 | 09:18 PM
powermad's Avatar
well i would call him but he is not open at this hour. thats why im on here asking you guys. its only first gear in 4 wheel drive that does it. does that mean my first gear is slipping or a cable adjustment. since its all new parts it shouldnt be slipping unless somethings out of adjustment right?
Old Mar 5, 2009 | 12:01 AM
nickg's Avatar
Your description of the up and down boost thing sounds like what my truck does, Mines from the Torque Management crap. if I plant the go pedal, it feels like the old 4barrel bog on a 350 chev, it would not be so bad if it did not do it a couple times in a row
...may not be your problem thou
Old Mar 5, 2009 | 06:36 AM
dzlfarmboy's Avatar
Well it looks like your trans is pieced together with different brand name parts,and just a Goerend converter if I read your sig right. Seems like what your experiencing is the torque managment in the ECM is kicking in, because your new converter has tighter fluid coupling and wont let the engine rev enough to build boost before the ECM reads the limit of RPM to wheel speed while in drive. And when trying to build boost it fuels some, then defuels, and fuels again= boost going up and down. Then when you launch it it falls on it's face.
To solve your problem you need a BD RAD ( Racer Anti Defueler ) they are only required for the 01-02 dodges with the torque managment programed in the ECM.
Brett
Old Mar 5, 2009 | 09:49 AM
Mike D's Avatar
Yeah the title of this thread needs to be changed.
Old Mar 5, 2009 | 11:31 AM
Erik@LCD's Avatar
Yeah, Trevor, thats a TQ Management issue my friend
Old Mar 5, 2009 | 07:49 PM
powermad's Avatar
hmm well is this a easy fix, or is it something inside the tranny?
Old Mar 5, 2009 | 10:06 PM
Mike D's Avatar
Read the number 6 post.
Old Mar 6, 2009 | 02:28 PM
dzlfarmboy's Avatar
Maybe I should of used BOLD CAPS
Old Mar 7, 2009 | 05:46 PM
powermad's Avatar
what i meant by my last question was is it something easy i can do or does it involve going way into the tranny and doing a bunch of work that i dont know how to do
Old Mar 7, 2009 | 07:20 PM
nickg's Avatar
Torque management is in the ECM, its NOT in the tranny!
Old Mar 7, 2009 | 07:26 PM
powermad's Avatar
ok thanks. so does everyone who drag races a 2000.5-2003 truck need one because this is the first ive heard of it being needed. i know a lot of people that have a truck like mine that can do boosted launches with no problem and dont have one of these.
Old Mar 7, 2009 | 07:44 PM
nickg's Avatar
I believe a smarty (programmer) will just about eliminate it. it can be stacked with your edge.
and I believe its only 01-02 (might not even be in all 02 models) someone else might chime in and comfirm
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
