synthetic engine oil...worth it?
Old Jan 27, 2008 | 11:49 AM
  #46
Ph4tty's Avatar
You're right. Rotella 5w40 isn't really a synthetic oil at all, but it is refined to the point that is performs nearly as well.
Old Jan 27, 2008 | 11:58 AM
  #47
hink's Avatar
???? http://www.shell.com/home/Framework?...ellasynth.html Why is it labeled as a FULL SYNTHECTIC then?? Just wunderin.
Old Jan 27, 2008 | 12:55 PM
  #48
wcbcruzer's Avatar
Rotella T synthetic is a group III synthetic. Some others are a group IV or V.
Group III - severely processed/hydrotreated petroleum oil
Group IV - polyalphaolefin
Group V - esters , other
All 3 groups come from crude oil except group III is still made in an oil refinery, whereas IV and V are made in a chemical plant. Like Ph4tty said, group III is highly refined oil + additives, which makes it a synthetic. Synthetic oil basically means the molecules are all nearly the same size. All groups are synthetic but as you go higher in group number, the oil is more pure and the molecules of the oil are closer to the same size. That's why higher end oils are more expensive, costs more and takes longer to make. For the price and performance, I don't think you can beat Rotella T synthetic.
Old Jan 27, 2008 | 01:02 PM
  #49
hink's Avatar
All 3 groups come from crude oil except group III is still made in an oil refinery, whereas IV and V are made in a chemical plant. Like Ph4tty said, group III is highly refined dino + additives, which makes it a synthetic. Synthetic oil basically means the molecules of the oil are all nearly the same size. All groups are synthetic but as you go higher in group number, the oil is more pure and the molecules of the oil are closer to the same size. That's why higher end oils are more expensive, costs more and takes longer to make. For the price and performance, I don't think you can beat Rotella T synthetic.
Thank You.
Doj Dewd
Dec 14, 2013 07:38 PM
tnhtractors
22
Jun 23, 2009 10:48 PM
rico334
Jan 3, 2005 08:10 AM
herb
May 31, 2004 09:42 AM
kevinn
Apr 6, 2003 09:18 PM
