Changing To Synthetic Oil On Older Engine
Whats the thoughts on changing to a synthetic oil in an engine with 65000 miles that has been broke in on shell rotella ?
From what I have read is the molecules are smaller than regular oil so it will go through places the normal oil wont so you get leaks.I switched in an astro van with 150,000 miles on it and it instantly started using oil,I tried mobil 1 ,5w50 i think .I switched back to regular 20w50 and it doesnt use a drop between changes.I have since switched to 15w40 diesel oil in it and its doing great,its at 180,000 now.
I run synthetic and dont have any extra leaks over regular Rotella
. We've got a truck with over 500k on it, runnin synthetic, and not a single leak
Even if the truck did end up leakin a little oil, I personally think the benefits of synthetic highly out weigh a little lost oil
. I can go way over 10k on an oil change (synthetic) and only ~4k on Delo via oil analysis.
Scott
. I can go way over 10k on an oil change (synthetic) and only ~4k on Delo via oil analysis.Scott
I ran dyno oil until 150000 miles then switched to synthetic oil.....no leaks or consumption of oil 25000 miles later
If you have oil leaks now they will leak more with full synthetic there are some oils that are semi- synthetic that can be switched to without problems like Kendall SHP 15w-40
http://www.kendallmotoroil.com/content/hdeo.asp
http://www.kendallmotoroil.com/techd...HP_DIESEL2.PDF
nfsommer
Oct 13, 2007 11:20 AM
Duallydog
25
Oct 2, 2006 02:36 AM
rico334
Jan 3, 2005 08:10 AM
