Methanol injection
Methanol injection
I am just now starting to learn about this, does anyone here have a Meth/water setup and does it work good? is that the greyish white smoke you see on the pullin' videos before the black stuff?
Re:Methanol injection
I've set up and tuned a water meth system on a truck on our dyno and will say it worked great. It was a 03 Dodge auto that I squeezed a set of our twins into and it made 590hp and never broke 1250 degs even after a dozen back to back hard loaded pulls.
If you want a lot of info on the water/meth, contact Jim Fulmer as nobody has done more testing on the Dodges then him.
Theres also a big thread on the TDR about this: http://www.turbodieselregister.com/f...threadid=87558
Here is a place to go for more info. http://www.turboice.net/forum/index.php
This board is new but it should pick up.
Or if we can get enough intrest we could get a new forum started here.
Hey, Jim any thoughts on how this snowperformance kit will affect my PDR40 as far a life span? Also which kit are you guys running Stage 1 or Stage 2? Also any thoughts on HeadGaskets with this setup?
I would just just install it and test it for boost and stay at the recommended level, as far as the hit when it comes on, it doesn't hit like N2O so I doubt it would be a big deal, now having said that if your at 500(which is too much for a 40) and add water/meth and it pushes you to (lets say) 570 then the turbo is yours and you should be running Twins at that level....remember I started this rat race at 450 with Twins.
Jim
Jim
dogger
May 5, 2005 05:31 PM
2k3 ctd
Apr 30, 2005 10:55 PM
mcevins
Jan 13, 2004 11:30 AM
Jim Fulmer
Nov 22, 2003 08:21 PM
with DDII) I am on my way to twins.. just don't have the funds right now.
