look at this cummins conversion into short truck
Old Mar 31, 2006 | 07:12 PM
12valve's Avatar
I did some adjusting on a friends truck:
its a 1500 ram short box single cab, it had a v6 gas, in which he installed a cummins, to that one a bigger turbo...
[IMG] [/IMG]
Here is his home made 4 inch exhaust, from turbo to back,
with this funny looking 4" exhaust tip:
He rolled it by hisself
[IMG][/IMG]
how-s it?
Old Mar 31, 2006 | 07:21 PM
jughead's Avatar
1/2 ton cummins
it makes for a fun ride. see my sig.
Old Mar 31, 2006 | 07:22 PM
It's a big improvement over a v-6 gasser!
Old Mar 31, 2006 | 07:30 PM
12valve's Avatar
yes it is.
oh... now he put on "CUMMINS TURBO DIESEL" under the RAM 1500¨on the door.
i installed 4k GSK in his pump. and a plate
Old Mar 31, 2006 | 08:06 PM
Timberman's Avatar
Front suspension hold the cummins up OK? Neat project, looks like he's a talented guy.
Old Mar 31, 2006 | 08:31 PM
dodgeguy71's Avatar
I might have left the badges off the door so ricers would think it was just a horrible sounding gasser....then blow their doors off and leave them chokin in some smoke! That's a cool conversion though...that has to be something to look at.
Old Apr 1, 2006 | 12:32 AM
88bird's Avatar
i guess when you go to get insurance it'll be cool to honestly answer.. yes mam' it's a 6 cyl...."
Old Apr 1, 2006 | 08:44 AM
12valve's Avatar
thanks for your opinions...
untill now the front suspension holds, but he wants to put on some better-thougher-higher springs under it, so it will be higher, its a little low in the front.
Old Apr 1, 2006 | 09:14 AM
kandgo's Avatar
At least take off the V and Put a I in front of the 6, He will have to beef up the front end, but he will get what he puts into it back with all the fun he'll have. Goodluck,,Rick
Old Apr 1, 2006 | 02:25 PM
STACKED's Avatar
i think you might have some traction problems racing rice burners, if that rear axle holds up. you got a good start though.
Old Apr 1, 2006 | 06:25 PM
jughead's Avatar
1/2 ton cummins
9.25 rear strip 9 in. slicks so far no problems dont think it would work towing very heavy thought. 0 to 60 high gear only 6.1 street tires. a lot of fun truck
Old Apr 1, 2006 | 06:31 PM
12valve's Avatar
i didnt get exactly what you meant...
did you mean from 0-60 in 6.1 seconds?
ok..what about street tires? are your slicks street tires? how much are they?
Old Apr 1, 2006 | 06:46 PM
jughead's Avatar
1/2 ton
yep the torgue will get your attention. slicks were use at the strip. ran a best 1/8 of 8.6 with a worn out engine. good engine should run mid 7s.
DJ Turbo.
Nov 5, 2011 12:20 AM
ssleeper94
Jul 10, 2011 03:01 PM
90 power ram
Oct 30, 2010 08:42 PM
GCSS
Jul 10, 2010 11:11 PM
nbaggett89
Dec 11, 2008 09:13 PM
