Fuel Pressure and FASS system
Old Dec 14, 2009 | 09:04 AM
Awall's Avatar
I have 2 Holley Blue fuel pumps and they are grossly insufficient, even with my truck on fuel saver mode it drops to 0 fuel pressure WOT. I was thinking about getting a FASS system. Would this give me all the pressure I need? or do I need to replace the fuel lines with bigger ones, add a draw straw etc...? Thanks in advance, A.Wall
Old Dec 14, 2009 | 10:31 AM
ellerman's Avatar
A FASS or Airdog system is all you need.
Old Dec 14, 2009 | 02:46 PM
Awall's Avatar
Which one is recommended? I have heard a lot about the FASS and that it is a great system, havent heard much about Airdog. Would leaving one of the Holleys help anything?, hurt?
Old Dec 14, 2009 | 09:11 PM
ellerman's Avatar
If you get a FASS or Airdog you would remove both pumps you currently have. I say FASS or Airdog because I believe they are both a very similar design. Don't quote me but I believe one company is owned by the father(original design) and one is owned by the son. I think the two gentleman were once in business together but got a divorce and now you have two companies. I think that is a very short version of the story but don't quote me. Either way you go they are a good piece of equipment.
Old Dec 16, 2009 | 02:09 PM
steamfitter's Avatar
if go with the fass titanum 150 or larger youll need the suction tube
Old Dec 16, 2009 | 10:57 PM
Haulin_in_Dixie's Avatar
If you want to do it right go bottom feed, its easy and flawless.
Old Dec 17, 2009 | 12:31 AM
Tate's Avatar
A good way to get a slug of water too if you have poor fuel.
Old Dec 17, 2009 | 11:51 AM
Awall's Avatar
Whats a suction tube? Same as a draw straw?
Old Dec 17, 2009 | 07:29 PM
Oh you mean that with a draw straw the water is taken out? I have run millions of miles with a bottom feed and have one dodge with bottom feed, bottom feed protects you from water building in the tank and causing a major water problem. You have filters for this purpose, especially on a FASS.
Old Dec 17, 2009 | 08:50 PM
DodgenIt's Avatar
Youll be fine with the FASS 150 you mentioned Awall, No need to go any bigger unless your turning it into a comp truck.
The FASS 150 or Airdog 165 would be plenty for all your needs IMO.
I see 20 psi at idle and 13 psi FP at WOT with my FASS.
Old Dec 17, 2009 | 10:22 PM
I have the older bigger fass and run 15 wot and 18 idle.
Old Dec 18, 2009 | 12:59 AM
Tate's Avatar
Never said a draw straw takes out the water. But a draw straw isn't at the lowest part of the tank where water likes to settle. The bottom feed is. That was what my point was.
iamallcanadian
Mar 8, 2011 04:39 PM
KenC
Aug 26, 2007 02:59 PM
Timberman
Dec 15, 2006 09:12 PM
BCarmicle
13
Nov 7, 2005 04:20 PM
farmer dave
14
Jun 1, 2005 03:11 PM
