new head lights and fog lights?
its getting to be fog season here so i need some lighting help, my lights are so dim i run my brights almost all the time, now were getting fog so dence that u cant hardly see past the hood. the stock fog lamps just arnt doing anything, and yes i turn my brights off when i drive in the fog. i dont want to spend a ton of money but i need both problems fixed. iv seen some projection fog lamps that looked good but im realy not sure what i should be looking for. as for head lamps iv looked at HIDs, PIAAs, and projections. what houseings? is silver star ultras ok with the right houseing?
Headlight
I don't know if this will help or not but as far as your headlights go mine were in terrible shape and I used the 3M headlight restore from Advance Auto and it did wonders. Follow the directions and put the clearcoat on and it works great. I don't know if this helps your situation but if your lights burn and the plastic is foggy it will make them almost new. It also works on your foglights. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Headlight-Lens-Restoration-System-3M_7100089-P_N3312Y_T|GRP2074____
www.lmctruck.com sells the harness.
I have after market headlights, 10x better than stock, but still not great in wet/dark nights.
I went to a local Princess Auto store (surplus store) and bought some cheap 4 1/2 inch 100W and 50 watt fog/spot lights I wired them up to the old style floor switch, like they used to have in the old 76 chev trucks, The 4$ each 50watts are on with the low beams (I can turn them off) they are aimed fairly well and I dont get flashed by oncoming vehs. light improvement in low beam is night and day, for high beam the 100w's make night into day and I bet they light up the hi-way for 3/4 of a kilometer, for back up I added two 6inch 100W that I can turn on if needed. so for a grand total of 22$ I have lights!! the extra 6inches cost another 14$
go with the HIDs well worth the $$$ BUT for the fogs make sure you get the 3000K HIDs as they are yellow in color they will cut through the fog better then a higher K value.
my bad I ment 3000k is yellow
thanks 1882
thanks 1882
fade94
Sep 15, 2009 12:53 AM
fjbiker86
37
Dec 9, 2007 07:29 AM
patriot dodge
Nov 23, 2007 07:57 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
