egt and boost w/ comp & DD2's??
Old May 16, 2005 | 11:07 AM
0013's Avatar
hey--
just wondering what egt and boost numbers your all seeing w/ my set-up or similiar? at WOT, comp at 3x5 i see 35 PSI and close to 1200* on flat ground. im asking this question for troubleshooting purposes. thanks,
chris
Old May 16, 2005 | 08:46 PM
Kman9090's Avatar
35 psi I dont even see that on level five, I think around 28 psi is the most I've seen
Old May 16, 2005 | 09:56 PM
mkubacak's Avatar
32 psi or so on 5 x 5. Do not remember EGT's.
Old May 17, 2005 | 12:47 AM
CTD_Neil's Avatar
Don't have a comp and mine are DD3's but I see 38 psi.
Old May 17, 2005 | 01:07 PM
seabee's Avatar
kman you are only seing 28psi with a comp. i see 26 with just my van aakens box and its not near as much fuel as that comp
Old May 17, 2005 | 02:22 PM
CTD NUT's Avatar
28 psi is very low if your Comp is on 5x5......with my Comp on 5x5 and WOT in top gear, I can almost hit 35 psi - 33 psi easily....
Old May 17, 2005 | 09:05 PM
Ram2Pete's Avatar
Re: egt and boost w/ comp & DD2's??
Originally posted by 0013
hey--
chris
Well I could see 1250-1300 at the end of the 1/4 with Drag on kill 5X5 and about 35 psi with the boost elbow from the EZ box and sence Sunday when I installed the DD 2's and an adjustible elbow tightened down all the way and playen on I-5 I can see 45psi and about 1500 and will be at the strip in a couple of weeks and will find out my temps then
Old May 17, 2005 | 10:46 PM
dieselrob's Avatar
with my set up and comp on 5x5 i can hit 38 psi like theres no tomroo. egts on flat ground 1200. 7% grade can get hotter.
dodgediesel
14
Dec 14, 2006 09:54 AM
z1bigtom
21
Jun 22, 2004 10:44 PM
Cummnzpowr
32
Apr 7, 2004 03:42 PM
crashinaz
Aug 14, 2003 10:47 AM
HOHN
May 27, 2003 04:28 PM
