edge comp problems?
Old Jan 23, 2006 | 01:55 PM
curts99's Avatar
edge comp problems?
1999 cummins 4" straight pipe edge comp very little smoke on 5x5 sould i see alot of smoke? second comp ive put in thinking first one was defective, drove 2001 with comp lots of smoke any suggestions or answers?
Old Jan 23, 2006 | 02:03 PM
duallydave's Avatar
Talking
how does the power feel?is there a diference from setting 1-5?if not check your conection to the injection pump.also check the ground.she should smoke.before the injectors mine would smoke but not huge,with the injectors its huge till turbo spools up.check those conections,you may be in ez mode.
Old Jan 23, 2006 | 02:04 PM
curts99's Avatar
has great power some smoke at beginng of first gear till turbo spools up good ground and good fuel pump tap
Old Jan 23, 2006 | 02:58 PM
99 cummins's Avatar
With stock injectors if your truck is running good you probably won't get much smoke. As long as you have enough air to burn the fuel your injectors are sending through you should be smoke free. This is a good thing, means you have your truck balanced right on the air to fuel ratio. If you want smoke get a set of RV 275 injectors, turn the Comp up and watch it roll. But remember smoke means wasted fuel for daily driving.
Old Jan 23, 2006 | 03:37 PM
mx yfz 450's Avatar
My comp only works on setting 1*5 now.Sometimes it freezes.Egde said i needed the software update on it to keep this from happining I am going to edge to get the version 8.0 software update on wesnday. They say if you have a 7.0 version box that it would bennifit from updating the software. While i'm there i'm getting the drag mod wohoo.
Old Jan 23, 2006 | 08:59 PM
curts99's Avatar
my comp is the version 8.0 i know alot of smoke isint good hard on motor and waists fuel but it sure is cool thanks for the help im new to the diesel performance any suggestions on trans up grades ats makes good stuff dont they what about bd?
Old Jan 24, 2006 | 07:07 AM
Joe Diesel's Avatar
So how can you tell what version of software you have??
Old Jan 24, 2006 | 07:09 AM
BigBlue's Avatar
There should be a label on the back of the comp stating which version you have.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
