edge comp and edge (drag) comp???
what is the differences?? looking in adds i never see the choice between comp or drag comp, it always is just comp....can someone explain the differences to me???
The Drag Comp fuels till 3200 and the regular till 2700, go for the Drag Comp, but the regular is still very potent, some say the Drag version is like 140hp but Edge makes no mention of this( I think).
hmmm...i have looked through many catologs and such and have never seen a "drag" comp listed under edge products...its always just the plain ol comp...but then i see people on here sayin they have a "drag" comp...thats why i was confused...
Drag is a 100 dollar upgrade to the regular edge comp. They don't list it in mags or brochures cause it requires that you fax in a liability waiver that states you are aware that it is for race applications yada yada could cause engine failure yada yada, could blow your tranny.... A drag comp is equal to a Hot Juice w attitude. For the newer versions of the Juice, you simply plug in a code that they give you after your 100 bucks and faxed in waiver forms and then you have a level 6 option called Hot. On the comp module, you actually have to mail in your box and they reprogram the fifth level and turn it into a Drag tune. So in essence you lose the old lesser level five and gain the Drag tune for level five. The drag does not net more peak horsepower, it simply adds fuel sooner in the power curve and fuels as previously stated to 3200 RPM. It is faster cause it gives you more power sooner... has more area under the curve on a dyno sheet so makes more useable power.
oh ok...thanks for explaining that to me...it had me confused. i have looked and looking and all i find is the comp...never seen the drag...i wanted to check into it before i bought one...i already have a new ez on mine, but want to switch to the comp....didnt wanna waste money on a comp then find out for a little more i coulda had a drag comp..thanks for the good explanation!
The part number for a 2000 Truck is ecd2000hot or 01 it is ecd2000ahot 02 is ecd2000bhot. Ask edge about these numbers and you can order one ready from them, so you dont have to send it back and all that bs.
J7
J7
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
Desert Diesel
Jul 14, 2005 03:34 PM
rockjeep73
Mar 25, 2005 03:34 AM
MoreSmoke
Jan 7, 2004 09:40 PM
