eaton fuller trans
Old Sep 19, 2007 | 09:29 AM
  #31
cowboy_trucker's Avatar
what are people talking about they are slow to shift? if you double clutch and all that garbage they are. i drive a truck and can rage the gears pretty good, on wet pavement once i shifted 6 gears while spinning. 1 set of tires anyway
Old Sep 26, 2007 | 08:52 PM
  #32
Number47's Avatar
The ISC(8.3L) is the same block as the ISB(5.9L) and eaton fuller makes a 6 speed that they put behind the med duty stuff that is tuff as nails
Old Sep 26, 2007 | 08:59 PM
  #33
BigTXDually's Avatar
Hey bud if you get it to work i would love to see some pics. Ever since I rebuilt my first one of those things I have been wanting to put one in my rig, I figured it would be a good way to top off my mini big rig type setup i have going on
Old Sep 26, 2007 | 09:05 PM
  #34
Number47's Avatar
i would but i dont have the $$ to do it.
Old Sep 27, 2007 | 08:51 PM
  #35
24Vford's Avatar
its going to happen just not sure how soon
Old Sep 27, 2007 | 11:08 PM
  #36
ROADWARRIOR's Avatar
There was a guy on the TDR a couple of years ago that went by the handle "C series man" or something like that. He had an older body style Ford that he put a 8.3L and a 10 speed in. He had a lengthy write up on it and lots of pictures of his fab work to beef'n up the frame. When it was done, he got good mileage and had loads of torque.
I've heard of a few people putting 10 speeds in Dodges before, but haven't seen one.
Dan
Old Sep 28, 2007 | 01:15 AM
  #37
Ph4tty's Avatar
After looking at the catalog listed on post 16, it does look like that is a good option. The gears aren't much different between the nv5600 and an eaton six speed but the bigger setups just add more gears down low. I didn't really get into it, but the weight/size didn't seem too radically different from the nv5600 either.
Old Sep 28, 2007 | 02:37 AM
  #38
Here is a link:
http://turbodieselregister.com/forum...-finished.html
Dan
Old Sep 29, 2007 | 07:35 PM
  #39
OutlawR6's Avatar
Best option I've found for something like this is an Eaton Fuller FSO-8406A, its a medium duty 6 speed with synchronized gears. Rated for 860 foot pounds of torque, has provisions for a PTO and weighs in at 359 pounds. From what I've found so far they can be had for around $3000 + $1000 core charge, and I think an SAE#3 housing is used to bolt up to our cummins engines.
Seems like the best option to me, it what I'm planing for when my auto gives out.
Old Sep 29, 2007 | 09:29 PM
  #40
24Vford's Avatar
i have a buddy that drives truck and has a eaton fuller 13 speed and he runs 65mph in 9th gear i hopeing to have more gear for the highway rather than down low
Old Sep 29, 2007 | 09:59 PM
  #41
24Vford's Avatar
Originally Posted by ROADWARRIOR
the pics would not open but it sounds like a nice job i wonder why he sold it sure seems like alot of work
Old Sep 29, 2007 | 10:38 PM
  #42
24Vford's Avatar
anyone know what the overdrive ration is on a nv4500,5600
or what the od ratio on a eaton 10 speed or 13speed
Old Sep 30, 2007 | 01:43 AM
  #43
Turbinator's Avatar
From another post:
Originally Posted by satburn
HTML Code:
NV4500
Final Drive Ratio
	Hi Range   Low Range
1	19.64	     53.21
2	10.64	     28.83
3	 5.85	     15.84
4	 3.50	      9.49
5	 2.63	      7.11
Reverse	19.64	     53.21
NV5600
Final Drive Ratio
	Hi Range   Low Range
1	19.71	     53.40
2	11.83	     32.06
3	 7.14	     19.35
4	 4.86	     13.18
5	 3.50	      9.49
6	 2.55	      6.92
Reverse	19.71	     53.40
Old Sep 30, 2007 | 11:57 AM
  #44
BCB's Avatar
BCB
4500 is .74 and the 5600 is .73 i believe
Old Oct 1, 2007 | 09:48 PM
  #45
24Vford's Avatar
the super 13 is .79 an .86 i belive
seems like a big diffrence from the nv5600
Exekiel69
Jul 19, 2009 10:32 PM
92GhostRyder
Oct 20, 2008 07:22 PM
Mglass1045
0
Jun 17, 2006 08:40 PM
WSnyder
0
May 22, 2006 01:59 PM
Nicholas
Dec 29, 2002 07:17 PM
