eaton fuller trans
Old Sep 16, 2007 | 06:48 PM
Jfaulkner's Avatar
Muted User
Originally Posted by 24Vford
so i need to cut the floor up it looks like how tall are they
Here is a link to the specifications guide. Keep in mind the physical size is just one small hurdle in a long list of problems you'll most likely run into.
Old Sep 16, 2007 | 06:51 PM
ct2500's Avatar
i dont think u will be able to have 4wd anymore.
Old Sep 16, 2007 | 08:11 PM
24Vford's Avatar
Originally Posted by BCB
no adapter needed just a standard bell housing off a med. duty 5.9, we got 3 of them at school.
can you pm me a part number for one of those
Old Sep 16, 2007 | 08:13 PM
24Vford's Avatar
i could probly run a divorced np205 tcase i think
Old Sep 16, 2007 | 09:38 PM
BCB's Avatar
BCB
no problem i'll have to get it 2marrow though
Old Sep 16, 2007 | 09:42 PM
BCB's Avatar
BCB
Oh a nother thing, i have talked with several people about this conversion and they all say i need to find a "baby 13" supposedly its just a 13 with a smaller case ect. used in some dump trucks back in the day... still workin on finding one...
Old Sep 16, 2007 | 10:39 PM
Ph4tty's Avatar
Originally Posted by cheapskate
why? have you ever drove with one of these? they are not fast, much slower shifting than a sycronized trans.
I drive both every day and most of the time I can shift an eaton faster than my nv5600 with a dual disk clutch. Clutch feels lighter on the freightliners too
Old Sep 17, 2007 | 09:46 AM
cheapskate's Avatar
you use the clutch to shift a 10 or 13 sp. non-syncroed trans.? the shifts on these transmissions can be fast, but you have to shift at least twice as much as a 5 speed. i guess with a light pick up you could skip gears, and i have to admit it would be kinda cool. would make it feel like you were driving a "real" truck. i think with the size of these transmissions it would be a very tight squeeze.
Old Sep 17, 2007 | 10:33 AM
Ph4tty's Avatar
No clutch needed- that is the appeal of the eaton fuller trannies: clutchless shifting. I can do clutchless shifts with my nv5600 too, but its not as smooth.
Old Sep 17, 2007 | 10:50 AM
cheapskate's Avatar
yeah, i was just making sure we were talking about the same kind of trannys. i know all about floating gears, i get paid to do it.
Old Sep 17, 2007 | 07:06 PM
24Vford's Avatar
my nv4500 is very slow shifting with the dual disc
i should not have too much trouble fitting it cause i am going to cut the tunnle out install the tranny and build a new tranny tunnle
Old Sep 17, 2007 | 07:44 PM
BCB's Avatar
BCB
man if your gonna do yaa that why not put a Detroit or a 3208 cat in it?? now that would be cool....
Old Sep 17, 2007 | 07:57 PM
24Vford's Avatar
you know i would like to d a 8.3 cummins with a 24Vhead and p-pump is the 8.3 just like the 5.9 only larger?
Old Sep 17, 2007 | 08:20 PM
BCB's Avatar
BCB
I'm not positive but i thinks so, but everything is bigger
I know i have seen them with a big P pump on them
Old Sep 17, 2007 | 09:34 PM
24Vford's Avatar
now that would be cool 8.3 and a 13 speed
