DSS, 03 tracbar install difficulty ?
Old Jan 4, 2005 | 10:07 PM
Turbo Deeezle's Avatar
Question DSS, 03 tracbar install difficulty ?
I just ordered a DSS steering stabilizer, 03 tracbar, and conversion bracket. Are there any hangups I should know about before I tear it appart? I hear its pretty easy bolt on application but there are always ups and downs and tricks to everything.
Old Jan 4, 2005 | 11:21 PM
phox_mulder's Avatar
Just installed my DSS about a month ago.
Not difficult at all.
I asked the same question right before I tackled mine, should be easy to find that thread with a search
I'm sure the tracbar bracket will be fairly easy as well.
Only thing I can see is your truck is a bit older than mine, so your original parts will probably be harder to get off.
Start soaking them with penetrating oil a couple days before you jump into it.
phox
Old Jan 5, 2005 | 02:03 PM
BIG&BAD's Avatar
i just have the dss
and it went pretty easy
the only thing is the pitman shaft nut is pretty big so that might be a issue?
im not sure about the size
Old Jan 5, 2005 | 06:01 PM
Lil Dog's Avatar
The track bar bracket takes a bit to get all the bolts to line up, but really its not that hard. I had some slag in the hole under the steering box where one of the bolts goes through, just had to drill it out a tad.
The DSS is a snap. I just made sure I had it all centered before snugging it up and then put on the bearing, just like the instructions say. Don't jump ahead, just go step by step. Piece of cake.
I had both setups installed in about 2 hours including cleanup.
Old Jan 5, 2005 | 08:36 PM
Originally posted by BIG&BAD
i just have the dss
I am not sure I follow you on this one? I have my fathers shop to use for this and he has every wrench and size available...... if thats what you mean?
Old Jan 5, 2005 | 08:39 PM
You'll probably be ok then.
I didn't have one that came close, so I had to make a couple trips for tools.
phox
Old Jan 5, 2005 | 10:06 PM
Lil Dog's Avatar
The nut on the pitman arm is like 32 mm if I recall, and the nut-shaft going on is 1-1/4". Fortunately I had a full metric set of wrenches, my sockets weren't big enough. (Maybe I should reword that... )
Old Jan 24, 2005 | 08:41 PM
AK2STAY's Avatar
Did any of you have your problems with the Trac-bar lining up? I had to use a drift and some grunting and groaning to get it to finally line up. It looks like it push the left side over a bit. Sound familiar to anyone. The DSS bracket made a big change.
What about realignment ?
tanderson2002us
Apr 6, 2010 01:38 PM
countrymanlife
May 24, 2009 01:14 PM
Ghost Ram
May 10, 2008 07:18 PM
Turbo Deeezle
13
Jan 14, 2005 08:42 PM
Palmetto_kid
Dec 22, 2003 04:33 PM
