NV4500 and 5th gear issues?
Old Dec 9, 2009 | 09:20 AM
lvmknsmoke..'s Avatar
hey guys, when i bought my truck a year ago my buddy said the one thing about the 5 speed is 5th gear tends to go out.. well ive had a lot more grinding and kinda whining noise comin from the stick when its in 5th and i was just wonderin if yal think it may be goin out? and if it is wat needs to be done to fix it? do i need a whole new trans, or can i just fix that gear?? thanks
Old Dec 9, 2009 | 09:42 AM
CODODGE2500MAN's Avatar
I believe that this is due to the 5th gear nut backing off.... Sorry, I've got an auto. Try a search for "5th gear nut" and there should be a good many threads to help you get that fixed.
Others will chime in too.
Old Dec 9, 2009 | 09:46 AM
STate's Avatar
You can buy kits like this one: http://www.puredieselpower.com/catal...ut-p-9533.html
And this is a good write up with pics. on how to do yourself.
http://www.dieselbombers.com/dodge-t...ining-nut.html
Scott
Old Dec 10, 2009 | 02:20 PM
Lil Dog's Avatar
This is a good site with good info/parts..
http://quad4x4.com/
Old Dec 12, 2009 | 09:20 AM
so yal think thats what it is? um if i push my shifter al the way to the right in 5th, the grinding kinda noise stops. also how hard, and would it be worth it, swapping in a 6-speed? or am i better off just rebuilding my 5-speed? my truck has 275k on it and i plan to build it to 500+ hp. how much longer do you think my "old" transmission will hold up? i am not particularly nice to it. lol
Old Dec 12, 2009 | 09:45 AM
cmac's Avatar
i would stay with the 5-speed. the 6-speeds are alot more expensive to fix and it is harder to find parts for them. you can fix the 5th gear without taking the tranny out if you just get the updated nut. its not the "best" option but it works and it is around 100 bucks from the dealer. i made my own "wrench/socket" for the new nut and if you put the tranny in reverse when you are doing it you dont need the other special socket to go on the end of the shaft.
Old Dec 12, 2009 | 12:46 PM
so you guys are certain its my 5th gear nut?? i found the nut somewher on some site for forty bucks.
Old Dec 12, 2009 | 07:19 PM
cmac's Avatar
it sounds like it to me but it is hard to be certain unless your 5th gear goes out or you take it apart.
Old Dec 13, 2009 | 04:48 PM
patdaly's Avatar
I'm not, mine is out and it doesn't make a sound.......But you won't know for sure until you get the tailhousing off.
Old Dec 13, 2009 | 07:15 PM
DRD's Avatar
DRD
When mine went it didn't make a sound. Tranny was working perfectly until driving along with the cruise on it just revved up. It took me about 10 seconds to figure out what was up, I thought it just popped out of gear.
LemonDodge
Sep 7, 2019 03:51 PM
Chass
0
Jun 19, 2011 02:05 PM
LemonDodge
Sep 16, 2010 07:33 AM
WHIFF
Oct 1, 2004 07:56 PM
whiteknight
Dec 27, 2002 06:28 PM
