Welding 5th Gear Nut to 5th Gear?
Old Aug 25, 2010 | 02:11 PM
LemonDodge's Avatar
I've heard about doing this from a couple tranny guys and i'm wondering what any of you guys have heard and if you think it would be a good idea to do
Old Aug 25, 2010 | 04:40 PM
patdaly's Avatar
I wouldn't, they seem to break at the heat affected zone when you weld them.
Old Aug 25, 2010 | 04:47 PM
78jeepstang's Avatar
Probably depends on how you do it & what filler you use. I wouldn't use mild steel with a MIG welder if I had to do it, i'd probably TIG it.
Old Aug 25, 2010 | 05:40 PM
dieselfreak21's Avatar
after just going through this and having it over hauled, I would look up Quad4x4 on google and if your hasn't broken yet or just the 1st time, i would get his replacement nut. After reading his stuff and examing the stock stuff and the weld option his option really makes sense. My nut broke, welded a new one to the shaft. Broke 200 miles later. Only towing gross of 20k and chip turned down.
Old Aug 25, 2010 | 06:34 PM
infidel's Avatar
Welding is a short term bandaid.
This is the right way to fix it> http://quad4x4.com/NV4500%205th%20Ge...0Solutions.htm
Old Aug 26, 2010 | 08:02 PM
Clayten's Avatar
DTR's Toad Wrangler
If you are going to weld it, double nut it and then weld the two nuts together,don't weld on the shaft.
Old Aug 26, 2010 | 08:05 PM
twichit's Avatar
i welded mine pretty much all the way around with the old miller stick welder with good heat setting on it and i just done running a 1200 mile trip with it ,to me it seems fine
Old Aug 26, 2010 | 08:41 PM
1-5-3-6-2-4's Avatar
I welded my nut to the shaft about 4 1/2 years ago now. stitched it good and hot 7018 iirc. I abused the bag off that truck, no issues. sold it since an its still on the road just fine.
Old Aug 27, 2010 | 11:08 AM
lgp9999's Avatar
I wouldn't weld it to the gear, as gears are usually case hardened and I have reason to believe that it will effect that hardening. Here's what I did:
https://www.dieseltruckresource.com/...h+gear+nut+fix
Almost 2 years now and never another issue.
Old Aug 27, 2010 | 08:31 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Thats what I did...double nut with lockite red,torque to 300 ft/lbs each nut and mig welded both nuts together in four spots...Did this about 4 months ago and haven't really drove the truck much yet..
Old Sep 16, 2010 | 07:33 AM
12valvewagon91's Avatar
When I would have one do that, I would spend the cash, and buy the output shaft that has full splineswhere the 5th gear goes on the shaft. Its the problem, there isnt a 100% contact on the gear to the splines, and no matter how tight you put the nut on, or unless you weld it, the gear walks on the shaft, and it comes loose. Its purely a badly engineered part. Thats it. When we went with the fully splined shaft, we never welded another nut, and it curred the issues. Never saw another one come in the door unless it hasnt had the upgrade yet.
Kasey
LemonDodge
Sep 7, 2019 03:51 PM
Purplezr2
Mar 19, 2011 10:03 PM
wadecool
Nov 13, 2006 12:37 AM
Cummnzpowr
Jun 25, 2004 12:17 AM
MCB56
Apr 16, 2004 11:38 AM
