weird starting
Old Aug 11, 2005 | 11:14 AM
Jambbii's Avatar
weird starting
My started has been acting funny on my truck, it cranks real slow, almost stops then it will speed up and start. Batteries are pretty good. It does it most of the time and sometimes it will start normal. Its reminds me of cranking a gasser over with too much timing. Is my starter dying?
Thanks
Old Aug 11, 2005 | 11:35 AM
infidel's Avatar
My bet is your batteries need replacing.
Old Aug 11, 2005 | 11:46 AM
Jeremy Cusick's Avatar
Have you put the upgrade starter solenoid contacts in it yet? The originals are probably worn out. You can get em off ebay pretty cheap.
Old Aug 11, 2005 | 11:59 AM
Geico266's Avatar
See my pics for a look at starter contacts and how they wear. They are easy to replace. Click on the link below for parts and info.
http://www.fostertruck.com/dodge/default.htm
Old Aug 11, 2005 | 12:49 PM
handymantim's Avatar
When you check the batteries be sure and disconnect both and have them load tested. They can't be tested together and just doing a voltage check won't be enough. They have to be put under a load.
Old Aug 11, 2005 | 01:49 PM
Jambbii's Avatar
going to get the batteries load tested today......
Old Aug 11, 2005 | 03:19 PM
Jambbii's Avatar
Well, infidel is right but I only have one bad one. I think I might try running one optima for now.
Old Aug 11, 2005 | 07:17 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
as a standard swap i don't recommend changing just one especially for an optima the voltage drop and cycling abilities are signicantly different. you should change both to be safe
Old Aug 11, 2005 | 07:53 PM
In other words, If one's bad, the other's not far behind.
Old Aug 12, 2005 | 09:26 AM
infidel's Avatar
I think he'll be just fine running one battery for now and maybe all year in AZ
Old Aug 12, 2005 | 05:10 PM
Jambbii's Avatar
I would change both of them but I am quite poor at the moment (right side hub died, just did twins) so one has been working fine for me right now.
Common
Apr 9, 2008 10:25 PM
MFEUSAF
Oct 28, 2007 08:46 PM
Ridiculous
Jul 28, 2006 06:05 PM
razor6
Mar 8, 2006 09:00 PM
Big Smoky
May 27, 2005 12:12 PM
