weird starting problem
Old Oct 28, 2007 | 06:40 PM
MFEUSAF's Avatar
For a few weeks now i ould go to start the truck and it wouldnt even crank. then i hit it again and it would start right up. or it would chug along untill it fired. anyways. i went out today to start it and same thing happens.. hit it once. nothing. hit it twice really slow cranking but not fast enough to start it. so i let off the key and its still cranking.. so then i take the key out of the ignition.. and still it cranks. ok this is where i got freaked out. so i popped the hood and pulled the batt calbes to get it to stop. has anyone ever heard of this?
Old Oct 28, 2007 | 06:54 PM
dj_souvlaki's Avatar
probably a bad solenoid
Old Oct 28, 2007 | 07:42 PM
lester23's Avatar
yup your starter, seloniod is on its way out, will leave you stranded somtime soon
Old Oct 28, 2007 | 07:49 PM
vzdude's Avatar
DTR's 'Go to Guy'
Look for a solenoid contact kit. There are 3 pieces in the solenoid that wear out/stick. You can get an upgraded heavy dity kit, or standard duty kit. I've seen a bunch of them on e-bay, or your local parts store may be able to get them.
Old Oct 28, 2007 | 08:24 PM
MFEUSAF's Avatar
yea but how could it still get power after i pull the key out and still crank the engine?
Old Oct 28, 2007 | 08:34 PM
vzdude's Avatar
DTR's 'Go to Guy'
The contacts stuck. The starter has power all the time. The solenoid wire is what tells the contacts to "pull in" and give the starter the juice. When they stick, you can take the solenoid wire out of the picture.
Old Oct 28, 2007 | 08:37 PM
papaduck's Avatar
Bad contact between the points and the high current draw caused them to weld together.
Old Oct 28, 2007 | 08:46 PM
MFEUSAF's Avatar
sounds like im going to be dropping the starter and fixin that solenoid soon. http://www.fostertruck.com/dodge/default.htm has explained alot for me and diecent price for the kit. thanks again !
jwayne575
Jul 29, 2010 09:18 PM
Common
Apr 9, 2008 10:25 PM
razor6
Mar 8, 2006 09:00 PM
Jambbii
Aug 12, 2005 05:10 PM
Big Smoky
May 27, 2005 12:12 PM
