hard/weird starting
Old Mar 5, 2006 | 09:52 PM
razor6's Avatar
hard/weird starting
ok... last night i went out to start my truck and when i did it took like 6 seconds of cranking on it to finally start... once it started it sounded like it was barely even getting enough fuel to keep running. so i turned it off right away and tried it again and it started just fine, i kept doing that a couple times and on like the 5th time i did it again it did the same thing, crank for about 6 seconds and barley had enought fuel to keep running but i left it alone and it was running fine... even some times when im about to stop and i put it in neutral and let off the gas and my rpms go up a couple unrded and drop a couple hundred to normal and back up a couple hundred and the backs down to normal. any way does this ever happend to anyone else???? thanks for the help!!!!
Old Mar 8, 2006 | 09:00 PM
RCW's Avatar
RCW
Check the wire from your AC system pressure sensor where it goes behind the engine. It is likely frayed. I also sent you a PM regarding the other probable cause.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
Common
Apr 9, 2008 10:25 PM
abc4yew
Mar 15, 2007 11:55 PM
Big Smoky
May 27, 2005 12:12 PM
