razor6 |
03-05-2006 09:52 PM |
hard/weird starting
ok... last night i went out to start my truck and when i did it took like 6 seconds of cranking on it to finally start... once it started it sounded like it was barely even getting enough fuel to keep running. so i turned it off right away and tried it again and it started just fine, i kept doing that a couple times and on like the 5th time i did it again it did the same thing, crank for about 6 seconds and barley had enought fuel to keep running but i left it alone and it was running fine... even some times when im about to stop and i put it in neutral and let off the gas and my rpms go up a couple unrded and drop a couple hundred to normal and back up a couple hundred and the backs down to normal. any way does this ever happend to anyone else???? thanks for the help!!!!
