Defrost only?
Old Aug 9, 2005 | 06:08 PM
stoneman's Avatar
Defrost only?
I can only get air to come out the defroster. I can get under the dash and manual move the defrost actuator thing and it will go to the vents. I let go & defrost only. The vacum line to actuator is on. I replaced the actuator 1 yr ago. What else do I check?
Thanks CB
Old Aug 9, 2005 | 10:51 PM
2 busy's Avatar
dont know about the 97, but check all the vaccumn lines. can you feel any suction at the line when you disconnect it.
I acidentally pulled a line loose installing gauges and all i could get was air out the defrost till i found the leak.trace the line out and check all connections.
Old Aug 9, 2005 | 11:23 PM
AggieJustin's Avatar
Check all the vacuum lines along the firewall under the hood. I've knocked a connection loose working under the hood before (a couple of times). Also had a friend's truck where the line fell against the exhaust housing on the turbo and melted in two.
Old Aug 10, 2005 | 07:19 AM
widelod's Avatar
It's vacuum somewhere.... one of those "odd federal mandates" where if there is a failure air must be directed out the defrost
Old Aug 10, 2005 | 05:34 PM
RATTLINRAM's Avatar
I have done the same thing,,,,,, two votes for one of the vacuum lines under the hood along the firewall.
Old Aug 10, 2005 | 05:58 PM
Mopar1973man's Avatar
Make it three votes for failed vacuum.
If you listen closely you might be able to here it in the cab if its leaking.
Old Aug 10, 2005 | 06:03 PM
stoneman's Avatar
i removed the actuator and it operates fine with suction applied. Still no suction from the line that connects to it. I will track down the vacum line from under the hood.
Thanks
Old Aug 11, 2005 | 02:35 PM
stoneman's Avatar
I found a hole in the vacum line right by the driver side battery. All seems to work fine now. Should only be few weeks until something else breaks.
Thanks for the replies
Old Aug 12, 2005 | 07:20 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Come on, this ain't a Ford we're talking about!!!!
bobem12
Jun 17, 2008 12:14 AM
mwolfe
Dec 20, 2007 05:50 AM
cbschmidt
Dec 14, 2007 08:02 PM
nickpay
Apr 14, 2006 06:24 PM
7mmrum
Nov 11, 2004 07:08 AM
