Blower only works on defrost mode
Old Oct 31, 2004 | 04:43 AM
7mmrum's Avatar
I recently switched the relay for the fuel shutoff soleniod, upon doing so I disconnected the Heater Relay. I put everything back together and now I only get the air to come out of the defrost vents. I have tried every setting, hot-cold, but it only comes out on defrost. I checked the relay again on the heater, it seemed fine, no bent prongs, or loose wires coming from the wire loom. The only thing that I can think of, is in a prior post I read some said that it is vacuum powered and that one of the lines may have come loose???
Any thoughts.
Thanks,
Old Oct 31, 2004 | 02:52 PM
Dojman's Avatar
That's definitely a possiblity. I had a line melt after it came loose from the ties and fell down on the turbo. defrost is all I got after losing vacuum
Old Nov 1, 2004 | 09:26 AM
CoastalDav's Avatar
Mine went to defrost some time ago and I found a vacume line off at the firewall on the drivers side. I was playing with the stink rubber thing that keeps the engine are out of the intake vent for the AC.
Dave
Old Nov 1, 2004 | 04:31 PM
stoneman's Avatar
I had to replace the defrost actuator arm when mine did the same thing.
Old Nov 2, 2004 | 11:44 AM
earl78621's Avatar
Mine use to do the same thing ended up being a vacumm hose cracked
Old Nov 2, 2004 | 12:14 PM
Tmc243's Avatar
I have a vacuum line just above the AFC housing that I knock off every time I do anything in the AFC area. I go for a test drive and stop at the first stop sign and hook it back up and all is ok again. I would start by looking for any loose vacuum lines. Good luck and lets us know what you find.
Old Nov 11, 2004 | 07:08 AM
7mmrum's Avatar
Yep, turned out the vacuum line was off the pump near the front of the engine block,, Working good now.
98Slushbox
Feb 14, 2010 12:42 PM
moto953
Jan 16, 2010 09:42 AM
HappyGA
Apr 30, 2006 08:47 AM
stoneman
Aug 12, 2005 07:20 PM
crossy
Nov 1, 2002 05:16 AM
