which way to loosen fan???
working on the first gen and going after the KDP. just need to know which way to loosen the 1-7/16" fan nut. i tried both ways already so now that i have to really whack it i want to be sure i going aftr it the right way. thanx . crossy
SO IT'S RIGHTY- LOOSEY OR CLOCKWISE I GUESS.
Dave i never saw the way you do that but this eems like it's easy enough. I guess I'll fab a tab since i did not order one. i just decided to do this this morning cause the front end is off. Need sleep right now. up ALL night, one more then off for 3 days . thanx for the offe r,
crosys(sp)
see told you i needed sleep
crosys(sp)
hey, I got this cover off and i'm guessing that you can drill/tap right from the side of the case and 'PIN' this in with a set screw or something? Is that the alternate method. bet you don't even remove these covers ? thanx , crossy- night.
