Stalls when put in drive or reverse
Old Jan 15, 2009 | 10:17 PM
nova7163's Avatar
I already posted in another section but truck is an 06 Mega Cab automatic. Truck idles perfectly but when you go from neutral to drive or reverse it lunges forward or reverse and then dies. Kind of like when you stall a manual trans. DTT said they think it needs new injectors but I still think it has something to do with the converter? Maybe stuck locked up? please help!!!
Truck has superchips and bored out injecters.
Old Jan 15, 2009 | 11:53 PM
dj88382000's Avatar
are there any codes being set? if so what are they? try un-plugging the connector for the fan clutch
K24612402
Vehicle Issue MIL. P2509. The engine may stumble or stall out.;12 volt power (unswitched) and the ground circuits to the ECM are good. Batteries and charging system operation are good. If applicable (2006 and 2007 MY trucks), the ECM has already been updated per TSB 18-001-07.
System or Component Die out / Stall,Hesitation / Sag / Stumble;DTC / Error Message;ECM
Recommendation If the problem can be duplicated, disconnect the fan clutch 6-way connector and check if the concern still occurs. If the problem no longer occurs, replace the fan clutch assembly.
Modification Date 01/04/08 9:57 AM
Old Jan 15, 2009 | 11:54 PM
dj88382000's Avatar
that would be the 1st thing i would check
Old Jan 16, 2009 | 10:12 AM
nova7163's Avatar
i haven't purchased the truck yet so I can't really check the codes. I will post again when I get it.
Old Jan 16, 2009 | 10:17 AM
flytrip's Avatar
Run away! Run away!
Old Jan 16, 2009 | 10:19 AM
Dieselbuilder's Avatar
your torque converter is toast. I have seen this may times old and new trucks
Old Jan 16, 2009 | 03:56 PM
nova7163's Avatar
Originally Posted by flytrip
Run away! Run away!
I am getting an 06 2500 mega cab laramie with 50k miles and 6" fabtech lift for 21k. You think its a good deal?
If the converter went out would it throw metal into the tranny or would it stay self contained?
Old Jan 16, 2009 | 06:47 PM
GreyTD's Avatar
If the tc took a dump, you would need to get the tranny flushed properly, along with the coolers and lines. valve body should be checked. Missing any steps would probably waste your time and money.
Old Jan 16, 2009 | 07:43 PM
hivoltage's Avatar
That was gonna be my guess too...sounds like the TC is staying locked?
Old Jan 18, 2009 | 11:13 PM
BigIron70's Avatar
Cummins Guru
I had two 2500's CTD come into shop this month with same problem. Dropped pan no metal found but did flush coolers and replaced torque converter. Under warranty of course.
dodge88
Feb 23, 2015 12:53 PM
DynamicalyUnstable
Nov 13, 2008 09:36 PM
stangpwr71
Sep 20, 2007 09:22 PM
Hounddog
Feb 14, 2006 06:33 PM
MIKE,J
Aug 29, 2003 09:26 AM
