shutdown solenoid
Old Jan 25, 2009 | 06:12 PM
fox1972's Avatar
shutdown solenoid
I have a 95 2500 auto CTD that will not start unless i pop the hood and help the solenoid into position. I have replaced the part and still have the same problem. It will stay in "run position" once you manually pull it up there. Any advice would be great.
Old Jan 25, 2009 | 06:19 PM
infidel's Avatar
The solenoid is probably the most needlessly replaced item on a 12 valve, expensive too. The solenoid is a very simple, sturdy device that will easily last the life of the truck. It either works or it doesn't, there is no such thing as one getting weak.
The problem is almost always a corroded blue wire from the driver's side battery or a bad relay on the firewall. The rubber boot that protects the solenoid can fall apart allowing gunk and rust to bind the solenoid, clean it up and replace the boot.
Relay and boot are availible for a good price here http://www.fostertruck.com/dodge/default.htm
ndtguy1
Nov 27, 2003 09:48 AM
mechanic
24
Sep 26, 2003 11:46 PM
Fishinghaoliboy
Jun 28, 2003 08:33 PM
Numero Uno
Mar 23, 2003 08:14 PM
taz1456
Oct 27, 2002 09:01 AM
