Plate Light Issue - New Bumper
Old Jan 25, 2009 | 04:54 PM
dirtygoat's Avatar
Angry Plate Light Issue - New Bumper
I have a new rear replacement bumper and just tried to wire in the Liscense Plate Lights! No luck. The lights do not work and the driver side rear tail light went out. I tried the blinker and the brake light the lights still work just not staying on. Any solutions?
Old Jan 25, 2009 | 04:59 PM
OldDodgeOwner's Avatar
What year truck do you have? On my 2000, I cut the wires on the factory license lights between the light and where it plugs into the main harness and soldered them to the new lights on the bumper.
Old Jan 25, 2009 | 05:04 PM
dirtygoat's Avatar
I have a 2006. The lights that came with the bumper has one wire. The harness from the old light has a white and black wire. I tried wiring seperately and running one to ground but no lights still.
Old Jan 25, 2009 | 05:18 PM
comptz's Avatar
Did you make sure your bumper has a good ground? On the truck in my sig the old lights went out and i bought new ones and i had to solder a ground to the metal casing on each and then connect the positive wire and then they worked and i havn't had an issue yet.
Old Jan 25, 2009 | 05:26 PM
On mine, I wired the hot wire from the truck to the light, then attached the ground wire from the truck to the bumper. The light grounds itself to the bumper.
Old Jan 25, 2009 | 06:29 PM
J BODY's Avatar
Always a possibility of damaging the TIPM when playing with light wiring on the new rigs. Star Scan may tell you if the drivers have been disabled.
schorb
May 1, 2007 08:18 AM
ocsurf16
Apr 2, 2007 03:41 PM
tanderson2002us
Mar 17, 2005 05:53 PM
c5r
Oct 27, 2004 05:41 PM
