fuel shutdown solenoid
Old Oct 25, 2002 | 07:00 AM
taz1456's Avatar
i wasa reading a bunch of post and came across one . <br>someone said that you can buy the boot on the plunger side from cummins. around here the dodge dealer and cummins dealers try to sell you the whole item. if anyone can tell me who and there address i can get the boot from. <br>it would be appreciated.
Old Oct 25, 2002 | 01:56 PM
Smokee's Avatar
Re:fuel shutdown solenoid
taz1456<br> <br> Welcome to the site. You should be able to find the address of the boot using the search. However, why not simply convert to a cable?<br>george<br> <br>
Old Oct 25, 2002 | 07:13 PM
taz1456's Avatar
been thinking of it. just that this solenoid still works . <br>if i convert what about relays do i remove them <br>i'm sure i can make it work
Old Oct 25, 2002 | 07:22 PM
taz1456's Avatar
also when i buy cable to convert do i need spring to pull the linkage in the up position and attach cable so that it will pull it down to kill
Old Oct 25, 2002 | 07:23 PM
Monty's Avatar
I understand a guy wants to fix something when it goes bad, but IMO I would leave it. And dont switch to a manual cable if the solenoid still works. The only thing that rubber boot does is keep out dirt and grime. If you cant find one, im sure you can come up with something to keep the dirt and grime out.
Old Oct 25, 2002 | 07:33 PM
taz1456's Avatar
i hear you about leaving it in . i have power to solenoid if relay works then power would get to the plug before solenoid right ? or is power from ignition then when you turn key would it then would relay react to pick up plunger ? i hear so much so i'm trying to limit what to look for
Old Oct 27, 2002 | 09:01 AM
Smokee's Avatar
taz1456:<br>Turn your key to the run position and then lift the plunger manually. It should hold up.<br>If it does, first check the power going to the relay. At the pos terminal on the driver's side look for a short blue wire that goes into a harness after about 3&quot;. These supply the power to the &quot;lift&quot; side of the relay. They have a habit of corroding off.<br>Next, unplug the fuel relay from the firewall (closest one.) replace it with another relay from the power centre aned try it.<br>Good luck.<br>george
ndtguy1
Nov 27, 2003 09:48 AM
mechanic
24
Sep 26, 2003 11:46 PM
Fishinghaoliboy
Jun 28, 2003 08:33 PM
Numero Uno
Mar 23, 2003 08:14 PM
