oil pressure guage
Old Jan 30, 2003 | 05:49 PM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
oil pressure guage
Smurff's 2000 2500 is indicating ~80 psi (end of tic marks) with the key in the on position, engine not running. Engine's getting plenty of oil, sounds good, all that stuff. Oil pressure indication does not change. Wasn't there something about sending unit problems a while back?<br>Please advise.<br><br>shortround out
Old Jan 30, 2003 | 06:02 PM
chuck3's Avatar
Re:oil pressure guage
Yeah, There has been a lot of guys replacing sending units.<br> Might go back and try a search to get more details.
Old Jan 30, 2003 | 07:08 PM
CharterBusDriver's Avatar
Id check the gage first. Hold down the trip reset button &amp; turn the key to the on position do not start, relese trip reset button &amp; wait it will do a system check. If all ok ckeck the sender and wire. Hope this helps.
Old Jan 31, 2003 | 07:26 AM
shortround's Avatar
Got a P 1693 code. Can't find in in my book. Any suggestions?
Old Jan 31, 2003 | 08:50 AM
For code use this link for info http://www.diagnosticdialog.com/LookupCode.asp
Diagnostic Trouble Code Description
Trouble Code: P1693
Vehicle Qualification: Dodge/Plymouth Trucks Quad Cab Pickup
Description: A companion DTC was set in both the ECM and PCM
Old Jan 31, 2003 | 01:05 PM
phox_mulder's Avatar
[quote author=shortround link=board=13;threadid=10299;start=0#98745 date=1044019564]<br>Got a P 1693 code. Can't find in in my book. Any suggestions?<br>[/quote]<br><br>P1693 is a generic &quot;code stored in companion ECM module&quot;<br><br>Pretty much any code in the PCM will also throw that code in the ECM. (as long as it is engine related)<br><br>PCM=Primary Control Module<br>ECM=Engine Control Module<br><br>phox<br><br>phox
Old Jan 31, 2003 | 01:08 PM
shortround's Avatar
That's the only code showing. Would the oil pressure sending unit cause it?
Old Jan 31, 2003 | 01:58 PM
Duelin's Avatar
My lil Brother sez<br><br> &quot; i went to cummins <br> hooked to computer $55<br>sending unit $69 <br>labor $108 <br>mis supplies$11 <br>$243 dollars later its fixed think i got ripped but its a done deal now. &quot; <br><br>Wonder why we get upset ?? <br>NO.......... I didn't say I told U<br>so !!
Old Feb 9, 2003 | 03:24 PM
Dieseldude4x4's Avatar
Mine just started that crap today. It goes to the far side of the 40 scale with the engine shut off. It must know I drove an 03 yesterday and is getting jealous.<br><br>Anybody got the proper fix for this other than the dealer?<br>Although the one in Williamsburg says they have a top notch hired by DC diesel mechanic.<br>I hate to take mine there with the EZ on it and have the machine hooked up. Probably cause more problems that it will solve.<br><br>May just disconnect that electric crap and hook up a mechanical gauge. That way, I know what I've got.
Old Feb 9, 2003 | 04:36 PM
shortround's Avatar
We just replaced the sending unit. ~40 bucks. Not sure cause we had a generator with a problem and we added a sending unit on the wish list.
Old Feb 10, 2003 | 12:27 AM
Now this evening on the way to work, everything read normal. Must have been a gremlin in the wires.
jrs_dodge_diesel
Jun 23, 2010 10:43 AM
mytrucksaslug
Dec 16, 2007 01:11 PM
jgiachino
16
Jul 11, 2007 07:33 PM
bigragu
Jan 24, 2006 11:16 AM
