Oil pressure
Oil pressure
On my '03 dodge the oil pressure drops down to 275 or lower at an idle. Just wondering if this was normal? Also noticing increased oil quantity on dipstick. It has around 257,000 kms, should I look into doing injectors and/or a bearing roll?
275? is that a misprint? also what's a "bearing roll"?
Sometimes there can be a trick to achieving a consistant oil level reading. Let engine sit for 15 minutes
Give the dipstick a gentle snap/jerk quickly all the way out. This aids in preventing the flex in the dipstick from brushing the tube top/bottom and giving a false higher level than actual. Try it several times and you will see the consistancy. Careful not to over do it and break the dipstick though.
When the engine is warm, it is pretty normal for the oil pressure to drop down to the middle of the gauge or a little lower when at idle.
Has it always behaved like this, or is this something new? Or is the truck new to you?
since the factory oil pressure gauge is getting its reading from the ecm and a 7 psi sending unit. Get amanual oil pressure gauge to see your correct pressure. My truck with cold oil and driving down the road usually sees 80 psi of pressure and 40 at idle with warm oil.
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
