tie rod end
Old Oct 20, 2010 | 11:11 AM
pwregan's Avatar
tie rod end
Hey guys,
I am finishing the passenger side of my truck- ball joints, hub, rotor, pads and i am trying to tighten the tie rod back to the nuckle- i had to remove the nuckle to get the ball joints out and in- now the tie rod stud seems to be spinning as i try to tighten it- will it stop if i put the truck down and get some weight on the suspension?
I am an electrician and i really have no business touchibng these things- but i tried and was doing well until this snag- i wont mention that i punched myself in the face loosening a bolt- guess i deserve it if i am going to fiddle!!
anyways need to get truck back up for tomorow- so any information will be greatly appreciated
thanks for everything!!,
Patrick
Old Oct 20, 2010 | 01:16 PM
Mexstan's Avatar
Are you using a socket to try to tighten it? Some tie rod ends require two wrenches to tighten. Check it the male part of the tie rod has a small hex on it. If it does, then use two wrenches (but not a socket) and that should solve your problem.
Another way is to clamp the tie rod to the knuckle using a large C-clamp. That way you can generate enough friction to stop the spinning and get that pesky nut tightened.
Old Oct 20, 2010 | 03:06 PM
pwregan's Avatar
tie rod end
thanks mex- i went and got a new tie rod- now trying to get old one out-any tips?
do they have a left hand thread?
Old Oct 20, 2010 | 03:12 PM
Hodge's Avatar
I put the jack under mine, and lifted some, putting enough pressure on the shaft to keep it from spinning until it would tighten.
Old Oct 20, 2010 | 06:24 PM
Mexstan's Avatar
The nut holding the tie rod in is a normal RH thread for both sides but one tie rod had a LH thread where it screws into the tie rod. Forget which one is which, but seem to remember that the RH side has a LH thread while LH side has a RH thread.
I am confused as I thought that you already had the tie rod out - or are you now trying to do the opposite side?
Don't forget to get a steering alignment done as soon as you have the new tie rod ends installed.
Let us know the results of your struggles.
ddestruel
Dec 7, 2008 06:37 AM
mr T
16
Feb 2, 2006 07:48 AM
Lil Dog
Jul 26, 2005 06:17 PM
Palmetto_kid
Sep 10, 2004 07:52 PM
Tengu
Jul 24, 2004 05:17 PM
