not getting fuel to filter
Old Dec 26, 2007 | 03:11 PM
big0078's Avatar
We think we have a 2004.5 dodge 2500 the problem is we cant get fuel to pump this truck doesnt have the lift pump on the side of the fuel filter/water seperator it has a line going in the side of the canister we have the tank down and tried to find elect in the 4 wires that plugs into the tank we tried key on then cycle key on off for each of the 4 wires. When we first started this journey the truck had a code P2509 we started testing and found a very bad battery we changed it but still no fuel we just dont know were to or how to test next does anyone have a suggestion thanks in advance
Old Dec 26, 2007 | 04:42 PM
FMB's Avatar
FMB
Welcome to DTR. The 2509 I believe has to do with your grid heaters not working. To see if your fuel pump is working, bump the engine (without starting) and the pump should run for 30 or 45 seconds. Is the truck still under warrantee (under 100k miles)?
Old Dec 26, 2007 | 07:47 PM
Spooler's Avatar
Should be a relay up by the driver's side battery that powers the intank fuel pump. Start checking at that point. Look for fuse also. Read of bad wires in this intank retrofit kit on some kits. Hope this helps.
Old Dec 26, 2007 | 11:26 PM
big0078's Avatar
Thanks we tried to do the bumping over thing several different ways still pump doesnt cycle truck is over on miles
Old Dec 26, 2007 | 11:35 PM
big0078's Avatar
Thanks do you know if there is a correct way to test for voltage at the tank we will go at it again in morning I just had back surgery so I have to have someone to help me we will find the relay then and test there first any other thoughts would be great thanks again LARRY
Old Dec 26, 2007 | 11:38 PM
big0078's Avatar
does anyone know of an online place to get wiring diagrams for this truck
Old Dec 26, 2007 | 11:51 PM
FMB's Avatar
FMB
where are you located? IM me.
Old Dec 27, 2007 | 01:05 PM
Spooler's Avatar
Wiring should be as follows.
1.) Old two wire connector that goes to old LP by motor.
2.) Connector goes to relay for the coil enigizer.
3.) Hot wire off of battery positive (fused) to one side of energized connection.
4.) Other side of energized goes to hot of in tank fuel pump.
Hope this helps. Schlematic should be on top of relay for what each connector does. Should be able to follow the wires from the relay.....
Old Dec 29, 2007 | 12:57 PM
big0078's Avatar
we found the problem where the dealer made the splices under the truck they didnt seal it at all to make long story short corrosion broken wires
M Penwald
14
Mar 26, 2011 08:41 PM
rick83864
Apr 20, 2010 09:08 PM
1Rodeoguy
May 4, 2008 11:59 PM
boiler-rat
Sep 5, 2005 12:59 PM
brandon507
Jun 19, 2005 10:03 PM
