Kickdown Band??
Old Sep 16, 2007 | 11:00 AM
Dinner's Avatar
Kickdown Band??
I have been doing some reading on the same problems as I am having right now, and think it may be the kickdown band in my tranny. The other morning, started the truck let it warm up a bit and then went to leave my friends place. Get onto the highway and the tranny goes through first, into second, start accelerating harder and it kicks back down to 1st and stays there. By this point I was turning a corner. So I accelerate like normal, but it won't shift out of first. I let off the throttle, start accelerating and it is in second...and it shifts fine through the rest of the gears.
Is this an easy fix to adjust/fix the kickdown band, or is it somewhat major work? And how long could I drive the truck like this for?
Thanks
Dinner
Old Sep 16, 2007 | 12:22 PM
Dinner's Avatar
Anyone? Would like to know so that I can perhaps get the downtime worked around my shifts
Old Sep 16, 2007 | 02:14 PM
j-fox's Avatar
I don't think it is the band or even the adjustment of it.
It could be the speed sensor, the presure sensor, or the pressure transducer. The first one is at the bottom of the OD case, the second and third are in the pan.
Old Sep 16, 2007 | 02:25 PM
ccoop769's Avatar
I know the kickdown cable on my jeep only took 5 seconds to adjust when it need adjustment
Old Sep 16, 2007 | 04:58 PM
Dinner's Avatar
What does the speed sensor read...how fast TC is spinning? And if it were the kickdown, im assuming it is the cable the runs into the tranny next to the gear selector. How would you go about adjusting that?
Thanks!!
Old Sep 18, 2007 | 01:41 PM
Dinner's Avatar
Had one of my mechanics look at my tranny quickly. The kickdown band is still there and working...so we hooked up the scan tool. Found that the governor pressure/voltage is too high. At idle it should be reading 0, my tranny was reading 50 I believe...didn't get a good look at it. Sooo I'm going to change out my Governor Solenoid and my Transducer Solenoid and see if that fixes the problem. Will report back once I have the parts and are installed.
And for anyone that knows quickly...where might I find these two solenoids?
Old Sep 18, 2007 | 10:03 PM
j-fox's Avatar
You will find them at a Dodge dealer, and at the valvebody!!
You are looking to spend about $150.
Old Sep 19, 2007 | 12:41 AM
Dinner's Avatar
Thanks j-fox
So just open up the pan behind the flex plate pretty much and change them there? Is there a diagram anywhere that shows which solenoid is which. I'm a noob when it comes to transmissions
EDIT: I've been thinking, if it's going to cost me around 200$ to get the two solenoids. Would it be a good idea to just buy a performance valve body and switch the whole unit over? I am wanting to upgrade the tranny anyways, so could I just do this for now...and then do the TC later on?
Thanks!
Dinner
Old Sep 19, 2007 | 06:59 PM
j-fox's Avatar
Most replacement VB's I think reuse the old sensors.
Call DTT and ask.
Old Sep 20, 2007 | 12:50 AM
Dinner's Avatar
On Goerend's website he has the "High Pressure Valve Body with solenoids" I am assuming this VB comes with the new ones but I will ask him to make sure. This is the route I am probably taking and so far he has responded with good emails
Dinner
hurtback
Dec 11, 2007 12:03 PM
th_racer
Apr 19, 2007 03:56 PM
garretch
Oct 2, 2006 07:00 PM
betsycam
Sep 26, 2004 03:44 AM
boughtadodge
Nov 28, 2002 11:49 AM
