anyone ever tighten the kickdown band too tight?
Old Oct 1, 2006 | 03:11 PM
garretch's Avatar
...anyone know happens if you do?
Old Oct 1, 2006 | 06:58 PM
infidel's Avatar
Rapid band wear is the result.
Overtightening is the reason most diesel tranny experts say not to adjust the bands unless you are experiencing slippage.
Old Oct 1, 2006 | 07:15 PM
garretch's Avatar
...well that sucks. mines not wanting to start off in 1st gear. it'll do fine if i put it in first manually. it'll do it more-so when it's warmed up.
Old Oct 1, 2006 | 07:59 PM
j-fox's Avatar
You may have a failing gov. pressure sensor and trans ducer. They are on the valvebody. About $150, if you do it yourself.
Old Oct 1, 2006 | 08:03 PM
Crimedog's Avatar
95 is all hydraulically controlled 47RH, so no gov pressure solenoid to worry about like in the 47RE. The only electronics are the lock up and overdrive solenoids. Give Dave Georend a call or do a search, I remember this being discussed a few times before but don't remember what the culprit is. Make sure you only look at threads with 94-95 transmissions (47RH)
Old Oct 2, 2006 | 06:48 AM
jughead's Avatar
kickdown band
if one tightens until the drum wont turn only have second gear. will bind up in 3rd and reverse. if one can turn the drum with ones hand nothing will happen.
Old Oct 2, 2006 | 04:27 PM
garretch's Avatar
i also dropped the tranny pan/fluid, changed the filter and put castrol multi-somthing atf back in. do you guys think it could be the fluid???
Old Oct 2, 2006 | 07:00 PM
jughead's Avatar
band
wouldnt care if one used motor oil it would work ok for a while. the first trans in the late 30s and early 40s used motor oil.
hurtback
Dec 11, 2007 12:03 PM
Dinner
Sep 20, 2007 12:50 AM
th_racer
Apr 19, 2007 03:56 PM
Dave88LX
Aug 23, 2005 06:39 AM
betsycam
Sep 26, 2004 03:44 AM
