kickdown band replacement in truck?
Old Dec 10, 2007 | 11:28 AM
hurtback's Avatar
Question kickdown band replacement in truck?
I have a 2000 cummins 3500 with 47re trans that has only 70,000 total miles. it has lost its friction from the 2nd gear band. I found parts of it in pan during service. It was hunting 1-2 shift under light throttle. I had the same hunting at 30,000 and I washed out the worn friction muck from solenoid and that fixed it. This time I got friction chunks from band but no metal. Can I replace the band in truck? they used to make snapin bands for fords but I can't ever remember doing one on a mopar. I hate to pull this trans since it has no other problems.
Old Dec 10, 2007 | 01:57 PM
j-fox's Avatar
Nope, the trans has to come out and front pump removed.
(why did I call it the front pump, it is the only pump!!).
It may need to front drum replaced or surfaced too.
Old Dec 11, 2007 | 08:04 AM
hurtback's Avatar
you called it front pump mostlikely from the days when some had a rear pump also. you must be old like me! I will try to cut off the band ancor tab and install it and spot weld it back on before i yank it out. the drum is fine because i didnt let it slip for long. the band had good linning left on it just failed maybe because of the hunting at 1-2 shift snaping the band on and off?
Old Dec 11, 2007 | 12:03 PM
j-fox's Avatar
Water can damage the lining too.
aborgardt
Jan 16, 2009 05:49 AM
Dinner
Sep 20, 2007 12:50 AM
th_racer
Apr 19, 2007 03:56 PM
garretch
Oct 2, 2006 07:00 PM
betsycam
Sep 26, 2004 03:44 AM
