Ip/lift pump
Old Jun 24, 2008 | 01:00 PM
bootsdodgejn's Avatar
Ip/lift pump
First off im letting neighbor use my screen name to dicribe his prob with his truck since his sreen name aint working.
Its a 2002 dodge 24v w/ edge juice w/ attitude, s&b cold air intake, banks 4" exhaust. I just started having a problem when its in park and you rev the engine it breaks up like it has a cylinder miss and it plumes white smoke out the exhaust and it has a shutter. but it only does it in park when we run it on the street it runs great no white smoke and it does not break up. it just ticked off 102,000 miles and the fuel pressure has dropped from 11 psi to 8psi at idle. can anyone tell me whats wrong????
P.S. it is throwin an injection pump timing code.
Can u adjust the timing on the injection pump????
Old Jun 24, 2008 | 01:24 PM
scottsjeeprolet's Avatar
Sounds like the LP is going out and maybe the VP44.
What pressure is he having at Wot?
What are all the codes it's throwing?
Start saving your money for a new VP.
We can put it on in the Cave.
AggieJustin's Avatar
Have you tried it without the Edge Juice on it? There is no way to adjust the timing, it is all controlled through electronics (which the Edge does). If it doesn't act up when the Edge is off, then you need to have the box checked out.
Have you checked/changed the fuel filter? That could be a possible cause for reduced fuel pressure.
Old Jun 24, 2008 | 01:30 PM
Yes he has taken the edge off.ill have him check it at wot.Ill let yall know by later on today.Scott i think it might come to that.
Old Jun 24, 2008 | 08:23 PM
ok here is an update
still havnt done Wot
But i do have codes
p 0500
p 1693
p 0237
p 0216
Old Jun 24, 2008 | 09:12 PM
cappykd's Avatar
From everything I've read when you get the p0216 along with the p1693 thats a bad or failing VP-44
Old Jun 25, 2008 | 08:33 AM
P0500 - Speed sensor (could be from spinning rear tires)
P1693 - Companion code
P0237 - MAP sensor voltage too low
P0216 - Injector pump timing failure
P0216 is usually the death code for the VP44, but I'm wondering why you have a P0237. Might need to check out the grounds and test the MAP sensor as well. Could be a bad sensor contributing to other issues.
Old Jun 25, 2008 | 02:40 PM
We will check the map.Also forgot to say when he reved it in parked he read 10 psi of boost.If im right that aint right.
Old Jun 25, 2008 | 02:51 PM
Yeah, that's not right. So either the Juice is misreading the signal from the MAP or the MAP is giving a bad signal. In either case, the computer is not seeing what it expects from the MAP.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
