How bad did I mess this thing up?
I put in a new turbo - garrett 3788 stg 3 and turned up my smarty to lvl 9. I'd only previously run it on lvl 3 with the stock turbo and 90 hp injectors. I towed a 7k trailer all the way to NY with no issues. Now I'm getting what seems like a low fuel condition. I have black smoke then white smoke then a popping noise (and flames) out the exhaust. The truck falls right on it's face then takes time to come back. This now happens back at lvl 3 also. I capped the fuel rail relief valve but still the same thing. I don't have a rail pressure gauge but I have on on the Walbro pump. I'm out of suggestions. I have an arson 2 kit on it.
I'm supposed to leave NY for VA on Sunday.
Sounds like your rail pressure is way down. You either lost an injector, or your not getting any fuel to the cp3. A bad injector would alow alot of lost RP, so thats where to look first.
I have the smarty to check codes so I'll start there. The truck starts and runs fine. Under heavy acceleration it falls out. It doesn't skip or miss. Any tips on looking for a bad injector?
White smoke, popping and flames out the exhaust is a unburned fuel build up in the exhaust.
Tim
I read the code. It's P0234 Turbocharger Overboost Condition. This is an early 04 and I have the wastegate on the smarty turned off. With the smarty off it runs fine. With the box on it will turn off the fuel.
There are a couple of ways to do this:
1. Easiest, injector kill test with a starscan.
2. Cap the rail one injector at a time.
3. Take off the valve cover and remove the wires from one injector at a time. Yes you can run the truck without the valve cover on.
LanceD
Mar 31, 2008 06:50 AM
dodge_kid9712
Jan 10, 2008 05:59 AM
kas83
Dec 11, 2007 05:37 PM
Bad Ramer Jamer
22
Dec 12, 2005 05:11 PM
