fuel problems
Old Oct 14, 2005 | 06:05 PM
strokethis3500's Avatar
fuel problems
my truck wont start on its own have to goose it with starting fluid. The injection pump runs strong theres no smoke. It looses prime as soon as i turn it off. I can bleed it off and it will catch prime and as soon as the lift pump kicks off it looses it. i can also play with the injector lines from the lift pump to the inlet side of the fuel canister and it fires off.. When it looses prime i can cycle the lift pump and hear what sounds like air coming out down by the lift pump??
Last edited by strokethis3500; Oct 14, 2005 at 09:05 PM. Reason: starts with starting fluid
Old Oct 14, 2005 | 07:36 PM
Geico266's Avatar
I just can't follow your problem here to help.
The injection pumps runs strong, but the truck won't start? I'm lost.
Old Oct 16, 2005 | 10:13 PM
farmer dave's Avatar
It could be some of the rubber in the fuel line is cracked. I would give it a check.
Old Oct 16, 2005 | 10:32 PM
dctoner's Avatar
Sounds like you have an air leak in your fuel system, save your LP and IP and redo your fuel lines. I have the FASS system but for the stock setup I hear the Vulcan system works great.
Check it out here.
http://www.vulcanperformance.com/dieselperfomance.html
Wade
Old Oct 16, 2005 | 11:14 PM
dig'umz's Avatar
The Vulcan kit is top notch
DJ Turbo.
Oct 13, 2011 09:11 PM
spooling
Apr 3, 2008 09:27 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
simmcows
Nov 18, 2002 10:58 AM
