Fuel Filter Drain
Old Apr 10, 2006 | 09:15 AM
CapeBob's Avatar
Fuel Filter Drain
Should have left well enough alone but decided to drain any water from my fuel filter. Well got some fluid off, than it stopped flowing, went to start it up and it started, but that started running rough and stalled. Now it won't start. Have loosen the banjo bolt, (not sure how much you are suppose to loosen it) but I am not getting much if any fuel coming out after I crank it and let the pump go for 25 seconds. How loose should I loosen the banjo bolt? How many times do I need to pump it before fuel should be coming out? How much fuel should I see coming out? And what do I do next?
Thanks for your help.
Old Apr 10, 2006 | 10:07 AM
P.O.R.'s Avatar
do you have a 12 or 24 valve,fill in your sig so we can see what you have.
Old Apr 10, 2006 | 10:40 AM
CapeBob's Avatar
Sorry, just updated my sig, but I have a 1998.5, 24 valve.
Thanks
Old Apr 10, 2006 | 12:27 PM
high country's Avatar
bump the key 2-3 times and then crank on it for a bit let it cool off and repeat....it should only take a few tries at the most.
Old Apr 10, 2006 | 04:53 PM
phox_mulder's Avatar
Sorry to report that your lift pump has left the building.
phox
Old Apr 10, 2006 | 06:54 PM
infidel's Avatar
phox
Many people don't know their lift pump is dead until they lose prime opening the system up and letting in some air since the injection pump will suck fuel.
One consolation is you are far from alone with this problem...
Recommend you visit the 24 valve forum and see what others are replacing their lift pumps with as a stock replacement will be short lived.
RDMueller
Jan 25, 2011 07:14 PM
ZPOD
18
Sep 23, 2010 10:37 AM
klx650a2
Jan 10, 2008 12:08 AM
Mechanos
Mar 8, 2004 02:30 PM
wooff
May 1, 2003 11:22 AM
