excessive crank times when hot
Old Oct 1, 2005 | 10:14 AM
kwwcc@aol.com's Avatar
2003 high output diesel excessive cranking time when hot, sometimes willnot start any suggestions?
kevinkwwcc@aol.com
Old Oct 1, 2005 | 10:21 AM
99 cummins's Avatar
Welcome to the wonderful world of Injector Pumps, might be something else but unlikely.
Old Oct 1, 2005 | 10:23 AM
99 cummins's Avatar
Forgot to mention if you need to start it when it's hot pour some water over the pump to cool it down and it may take right off. I got a few hundred miles more out of mine by carrying a cooler with water bottles in the back seat while I waited for my new pump to show up.
Old Oct 1, 2005 | 10:51 AM
hoser's Avatar
Shouldnt be the injection pump. If it was a 98.5 to 2002, then maybe. If you get smoke from the exhaust after a long crank time then i would lean more towards an injector leaking , causing the pump to crank longer before it can make enough pressure .
Old Oct 1, 2005 | 10:54 AM
J BODY's Avatar
You really need to monitor the rail psi with a scan tool and perform the fuel delivery tests.
Old Oct 1, 2005 | 11:14 AM
doorguy's Avatar
As said above , should have it scanned with a drbIII (dealers have them and some private shops have them) I had mine scanned at a private shop. Does your truck surge, any smoke.
Old Oct 2, 2005 | 07:55 AM
no smoke or surge, sounds like i have a similiar truck to yours with a service body
Old Oct 2, 2005 | 09:37 AM
doorguy's Avatar
Do you use a fuel additive?
Have you changed fuel filter?
Have you done the key trick to see if any codes come up(turn the key on and then off , do this three times without starting and if there are any codes they will be displayed in the odometer)
Get it scanned (check fuel pressures, I dont think it is high pressure side but the low pressure side (lift pump) just my 2 cents.
Old Oct 3, 2005 | 07:59 AM
The Code Diplayed Is P0480 Do You Know What It Means? Filter Has Been Changed
Kevin
Old Oct 3, 2005 | 08:02 AM
crobtex's Avatar
I don't know what it means, but: P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
bigfoot
Jul 29, 2009 02:13 PM
green73
Oct 14, 2007 02:43 PM
edwinsmith
Apr 14, 2006 03:53 PM
kully560
Jan 5, 2006 11:43 PM
duallydave
Aug 7, 2005 09:38 PM
