Died On The Side Of The Road
Old Jul 4, 2007 | 06:35 PM
  #31
EverydayDiesel's Avatar
Originally Posted by vzdude
Sounds like maybe a crank sensor, or cam sensor. I know you checked for codes, do you have a scanner or something to be able to read the data stream? If so, look at the cam and crank signal. Make sure they are both reading when it won't start.There is also a synch state. It should say cam/crank if they are o.k. The crank sensor is kinda likely. I've seen them do the same thing. The cam sensor should only show a light when it goes bad. It is used basically to get the engine going - shows computer when #1 is at TDC. The crank sensor should do the same thing by the different spacing on the tone ring. It just takes more revolutions to get teh engine to start using crank sensor only. Thats why they put the cam sensor in , to get the engine started quicker. So to make this long story shorter, next thing I would replace would be the crank sensor. You might save some money though by having it diagnosed by someone with a scanner. Would have saved the fuel pump money at least.
crank sensor seems to have fixed it. the car idles ALOT better now (not that it was rough before but its smooth as glass now)
I drove it 18 miles today (it usually breaks down in less then 2 miles) and it ran perfectly.
I really cant thank you enough andy
Old Jul 4, 2007 | 07:10 PM
  #32
vzdude's Avatar
DTR's 'Go to Guy'
Great! Glad it all worked out.
Andy
Old Jul 5, 2007 | 11:02 PM
  #33
hey andy, could you post the procedure for replacing the serpentine belt? It looks as if im going to have to remove quite a bit of stuff to replace it.
Old Jul 6, 2007 | 05:54 AM
  #34
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
GENERATOR/POWER STEERING BELT
The Poly-V generator/power steering belt has an adjustable tensioner pulley located on the front timing belt cover.
Loosen tensioner pulley locking nut.
Raise vehicle on hoist.
Remove the two (2) push clips attaching lower air shield to engine cradle. Remove air shield.
Loosen tensioner adjusting bolt until the belt can be removed.
AIR CONDITIONING BELT
Remove generator/power steering drive belt to gain access to the air conditioning drive belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
To remove air conditioning drive belt, first loosen the tensioner pulley lock nut, then loosen the adjusting screw to the tensioner pulley assembly until the belt can be removed (ACCESSORY DRIVE BELTS).
Old Jul 6, 2007 | 07:00 AM
  #35
atch's Avatar
Two more pages and he'll have the whole manual HAHA
Old Jul 8, 2007 | 06:17 PM
  #36
Timmay2's Avatar
lol can i buy an Andy for my toolbox?
Old Jul 8, 2007 | 06:19 PM
  #37
vzdude's Avatar
DTR's 'Go to Guy'
You can, but they are not cheap! And the eat a lot too! VERY high maintenance! LOL
wildcargo
Feb 16, 2009 09:14 AM
Spooler
Aug 5, 2008 06:21 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
dale s
Aug 23, 2005 08:48 PM
JerryB4
Oct 9, 2003 10:09 PM
