Died on the side of the road
Old Feb 14, 2009 | 03:12 PM
wildcargo's Avatar
Started her up this morning and drove 1/2 mile at 45mph and it just shut itself off. Took me a fue trys to get it to start, it ran allright after that and I stoped and restarted 5 0r 6 times with no problumes. When I got home I turned the key 3 times and got P 0500 and P 1693, any one know what the codes are.
Thanks Bud
Old Feb 14, 2009 | 03:34 PM
littlebuddie's Avatar
P1693 - "A companion DTC was set in both the ECM and PCM." That's what my
code program says. Sorry I can't tell you what that means. Sit tight, someone will know.
Old Feb 14, 2009 | 06:59 PM
WestTN's Avatar
P0500
No Vehicle Speed Sensor Signal
Old Feb 14, 2009 | 07:53 PM
crobtex's Avatar
The speed sensor is on top of the rear axle. It will effect the speedo (erratic) and usually set the ABS light, but never heard of one causing a truck to die.
Old Feb 15, 2009 | 07:49 AM
wildcargo's Avatar
Thanks. Maybe the outher code P 1693 has to do with it shuting it self down ? When I tryed to restart it it cranked a fue times no fire an then it coughed then fired on the next try. If I take it to some one with a scan tool can thay get a reading to tell me what's going on with the truck.
Old Feb 15, 2009 | 08:12 AM
crobtex's Avatar
All the 1693 means is that the code was recognized by both the ECM and PCM. Dieing like that could be a fuel pump loosing prime/going bad or the injector pump going bad (usuallys set a P0216 code), or the APPS going bad. If you don''t have a fuel pressure gauge, get one and check you pressure. That's the first place to start.....no fuel to the IP. A remote chance, but bad batteries or corroded posts can also cause a problem.
Old Feb 16, 2009 | 07:34 AM
dozer12216's Avatar
When all else fails, start looking for a VP44. And don't plan on long trips till resolved.
Old Feb 16, 2009 | 08:01 AM
Junk Man's Avatar
Parts stores rent scanners. Around here, Autozone & Advance won't clear codes. ORiley's will.
Old Feb 16, 2009 | 09:14 AM
wildcargo's Avatar
Well thanks for the replys. The P 0500 code explains the cruse droping out that sender was replaced 2 years ago . Hope the P 1693 code is not the VP44, this truck only has 60,000 miles on it , I was not planing on anouther truck for a wile 10 or 15 years maybe. At 64 I don't want to work on this truck eather, O well.
If I hook a gauge to the drain on the filter and lift the handel with the motor running will I get a presure reading or a mess. or do I have to find a fitting for the inlet on the injection pump.
Bud
Spooler
Aug 5, 2008 06:21 PM
EverydayDiesel
Jul 8, 2007 06:19 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
dale s
Aug 23, 2005 08:48 PM
JerryB4
Oct 9, 2003 10:09 PM
