Who's VP died from fuel box?? died stock??
Old Oct 25, 2005 | 04:39 PM
Tommy93w350's Avatar
I want to get a fuel box in the future, but it seems the guys that are replacing the VPs are the ones that have fuel performance boxes. maybe I'm wrong, it does seem that the boxes are adding a strain the VP and causes premature wear or overexertion on the VP.
What I want to know, how many pump failures have fuel boxes attached for fuel box related??
Old Oct 25, 2005 | 04:46 PM
Tiny's Avatar
I lost my pump the day after I put the Edge Comp on. But it had 123K miles on it, so it was not too bad.
Old Oct 25, 2005 | 05:04 PM
BigBlue's Avatar
I've got 87K on mine so far. I've had fueling boxes on it off and on over the years. Dead fuel pumps, running the tank low, etc, etc. So far so good. Personally, I think it's a matter of when, not if it will fail. We all know that a Comp will kill the IP sooner, but how much sooner? 50k miles? 15k miles? 10 miles? Did the comp actually cause the IP to die, or was it just the IP's time and it coincided with putting a comp on? Who knows. One things for certain, the truck is a heckuva lot more fun to drive with a comp than it is without.
Old Oct 25, 2005 | 05:21 PM
Buckshotmckee's Avatar
From what I've read around here, my thoughts are if your Vp is borderline and you tap the wire, it will push it over the edge.
Old Oct 25, 2005 | 05:40 PM
That makes a lot sense, if the pump is weak the box will kill it. I guess it's like the old saying, "Only the the strong survive."
Old Oct 25, 2005 | 06:33 PM
zukgod1's Avatar
I got 107K on my VP with a Comp box. From what I hear 107k is good without a box.
Two transmissions one VP.
Old Oct 25, 2005 | 08:25 PM
turbo dreams's Avatar
my vp went out at 199k. had an ez on it for about 10k before it went. it was just time for it to go.
Old Oct 25, 2005 | 08:33 PM
ramfreak01's Avatar
Mine went at 68000 and i've never had a box on it. but i love hearing the truck scream so that might have something to do with it.
Old Oct 25, 2005 | 11:16 PM
J BODY's Avatar
I've replaced a ton of stock ones over the "tapped" ones that have died.
Old Oct 26, 2005 | 07:06 AM
DuaneWKKC's Avatar
My VP died at approx. 75K, never had a fuel/timing box on it, my failure was electrical, not mechanical. Still have the original LP, I know... need to get PSI guage, but was tested at 9PSI WOT and 12 to 13 PSI idle.
DuaneW
Old Oct 27, 2005 | 02:15 PM
Gotlift01's Avatar
I have about 88K on mine and my VP is starting to take a crap on me. First start up of the day I get the big puff of white smoke and rough idling......after that it seems to be fine but I have a feeling that it is on it's way to a dirt nap!! Guess it's time for the HRVP44.............. I've had my COMP box on since about 80K so it could be caused from that or it could just be it's time......who knows???
~Nick
Old Oct 27, 2005 | 02:38 PM
nitrousn's Avatar
My 2002 was acting up with 62,000 miles and was replaced. Lift pump original with 67,000 now.
Old Oct 27, 2005 | 02:40 PM
DieselGoose's Avatar
im new to this list but i mine is going for sure. I had a weak VP and the box made it worse for sure. I had my engine cut out twice in three years before the box and last weekend the thing was cutting out bad when i was passing on a highway with the box on 5x5. turned it off and it is good for now. Need to fix it soon before i get screwed
Just wondering what you guys that have had yours go out do to replace it?? Just got with another VP44? Rebuilt/new? are there any after market or beefier options?? thanks
Old Oct 27, 2005 | 05:34 PM
FamilyDiesel's Avatar
VP failed at 115,000 miles. Everthing completly stock, no modifications at all. (no Fuel Pressure gauge, but I suspect the LP contributed to VP failure).
Old Oct 27, 2005 | 07:25 PM
phox_mulder's Avatar
VP went TU with 4K on the clock. (never heard why, but my bet is electronics)
LP still original with 50K on the clock.
No box, no inectors, no nothing.
phox
