Torque specifications?????
I have a 2006 Dodge Ram 2500 Quad cab diesel with auto tranny.
Need Torque specs. for front diff 9.25" 14 bolt
rear diff 11.50" 14 bolt
48 re auto tranny-putting on mag hytec pan
All help is appreciated.
Let me know if this is all you needed.
Mark
DR/DH FRONT AXLE - 9 1/4 AA 3 - 193
SPECIFICATIONS
AXLE SPECIFICATIONS
DESCRIPTION SPECIFICATION
Axle Ratio 3.73, 4.10, 4.56
Ring Gear Diameter 235 mm (9.25 in.)
Ring Gear Backlash 0.13-0.18 mm (0.005-0.007 in.)
Pinion Bearing Preload - New Bearing 1.7-2.8 N·m (15-25 in. lbs.)
Pinion Bearing Preload - Original Bearing 1.1-2.2 N·m (10-20 in. lbs.)
Pinion Bearing Preload + Differential Case Bearing
3.4-5.6 N·m (30-50 in. lbs.)
2.8-5.1 N·m (25-45 in. lbs.)
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Fill Hole Plug 32 24 -
Differential Cover Bolts 40 30 -
Bearing Cap Bolts 85 63 -
Ring Gear Bolts 140 103 -
Axle Nut 356 263 -
Pinion Shaft Lock Bolt 52 38 -
Adjuster Lock Bolt 25 18 -
3 - 320 REAR AXLE - 11 1/2 AA DR/DH
SPECIFICATIONS
AXLE SPECIFICATIONS
Ring Gear Diameter 292 mm (11.5 in.)
Pinion Bearing Preload - New Bearings 1.69-2.82 N·m (15-25 in. lbs.)
Pinion Bearing Preload - Original Bearings 1-2 N·m (10-20 in. lbs.)
Bearing Cap Bolts 281 207 -
Ring Gear Bolts 237 175 -
Axle Flange Bolts 129 95 -
Mark
SPECIFICATIONS
AXLE SPECIFICATIONS
Axle Nut 356 263 -
SPECIFICATIONS
AXLE SPECIFICATIONS
21 - 1038 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION
DR/DH
Fitting, cooler line at trans 18 13 -
Bolt, torque convertor 47 35 -
Bolt, clevis bracket to
crossmember
47 35 -
Bolt, clevis bracket to rear
support
68 50 -
Bolt, driveplate to
crankshaft
75 55 -
Bolt, Transmission Throttle
Valve Actuator
8.5 - 75
Plug, front band reaction 17 13 -
Locknut, front band adj. 34 25 -
Bolt, fluid pan 13.6 - 120
Screws, fluid filter 4 - 35
Bolt, oil pump 20 15 -
Bolt, overrunning clutch
cam
17 13 -
Bolt, O/D to trans. 34 25 -
Bolt, O/D piston retainer 17 13 -
Plug, pressure test port 14 10 -
Bolt, reaction shaft support 20 15 -
Locknut, rear band 41 30 -
Bolt, valve body to case 12 - 100
Sensor, trans speed 27 20 -
Screw, solenoid wiring
connector
4 - 35
Screw, solenoid to transfer
plate
4 - 35
Bracket, transmission
range sensor mounting
34 25 -
Screw, transmision range
sensor to mounting
bracket
5 - 45
crossmember
47 35 -
support
68 50 -
Bolt, driveplate to
crankshaft
75 55 -
Valve Actuator
8.5 - 75
cam
17 13 -
connector
4 - 35
plate
4 - 35
34 25 -
sensor to mounting
bracket
5 - 45
Thanks
Plenty of information.
All I'm doing in changing the diff covers front and rear with new oasis covers.
Am also changing to a new mag hytec tranny pan. Is the specs for the tranny approximately 10' lbs. on those bolts?
Actually, just saw the tranny info as well.
Diff: 30 ft lbs. on bolts
24 ft lbs. for fill and drain plug
Tranny: 10-15 on bolts.
Drain plug?
Thanks for all of your help. I really need to get this done and was struggling to find this information out. I really appreciate your help Mark.
Thanks. Chris
Drain plug?
Thanks. Chris
Oh by the way here's a link you can buy the complete service manual from. You will need cable to download it though. It's over 200meg's. It's only 20 bucks for the PDF file.
http://www.tradebit.com/filedetail.php/823941
Mark
Mark
A few people have broken dif cover bolts using a torque wrench set at 30.
I broke one on my 2nd change. Anyhow, I'd suggest going a little less than specified, or having a couple spare bolts and an extractor on hand, just in case.
surfram
0
02-19-2007 09:12 AM
Bobcat698
11-29-2006 05:47 PM
Svenne
0
01-19-2004 01:54 PM
Copenhagenjunkie
01-04-2003 11:54 AM
